03-12-2018, 03:13 PM | #1 |
78
Rep 129
F30 M Sport Brakes -- Pads and Rotors?
Looking for options on brake pads and rotors for a F30 with M Sport brakes.
These will be duo-purpose for daily and track. Been looking around and there doesn't seem to be many options available for this platform: Pads - OEM TRW - OEM M3 - Hawk 5.0 (are these available for this platform?) Rotors - OEM Zimmerman - Centric 125 series flat - Centric 126 series slotted Anyone run these options or have other recommendations? Not looking for dedicated-track-pads. Thanks |
03-12-2018, 04:29 PM | #2 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
I've heard EBC Yellows are a decent dual-purpose street/track pad. I don't have any experience with them since I run dedicated street/track pads (EBC Red/Pagid RS29).
For rotors there's also the OEM Hella/Pagid ones. -355120771, 370x30mm, two-piece, dimpled & slotted, 26lbs -355120781, 345x24mm, two-piece, dimpled & slotted, 19.2lbs -355120831, 370x30mm, two-piece, blank, 26lbs -355120851, 345x24mm, two-piece, blank, 19.2lbs For me, I bought a set of Stoptech ARK fronts (PNs: 129.34144.13, 129.34144.14, 24lbs each) and Hella/Pagid M-Performance (dimpled/slotted) rears. Aside from the Hella/Pagid, Stoptech ARK, and ECS Tuning ones, I don't know of any others that are two-piece. The Zimmermanns look like one piece based upon the pics on ECS. Last edited by FaRKle!; 03-12-2018 at 04:34 PM.. |
03-13-2018, 08:36 AM | #3 | ||
246
Rep 483
03-13-2018, 08:44 AM | #4 | |
78
Rep 129
03-13-2018, 11:05 AM | #5 |
4017
Rep 3,540
I own the Hella/Pagid dimple/slotted rears. They're 2-piece. Brake manufacturers are notorious for having bad photos (just look at Centric/Powerstop's site!), but the written description, although sometimes difficult to decipher, has never proven me wrong.
03-15-2018, 10:10 AM | #6 |
246
Rep 483
just out of curiosity... i looked at the pics again and I can see now that it does look like 2-piece but slightly different than the usual brake kit 2-piece rotors. Those usually have a light weight aluminum hat that is attached to the rotor with some bolts... the design of these 2-piece ones, similar to the zimmerman 2 piece rotors don't look like that. do they have light weight hats as well? is there a material weight savings to these?
03-15-2018, 10:59 AM | #7 | |
4017
Rep 3,540
Does the Zimmermann description say they're 2-piece? If it doesn't, and you don't see bolts or rivets holding the hat to the rotor, I don't think they're actually 2-piece. |
03-15-2018, 11:08 AM | #8 | |
246
Rep 483
zimmerman says 2 piece but i cant link the catalog directly because it's in a frame with no link but if you go to this link and put in car info there are 2-piece rotors available, not sure if they are available globally... http://www.otto-zimmermann.de/en/katalog.html |
03-15-2018, 12:32 PM | #9 | |
4017
Rep 3,540
PNs: -150.2911.32 M-Sport (blank) 2-piece 370mm front rotor. -150.2905.32 slotted 2-piece 370mm front rotor. -150.2911.20 1-piece 370mm front rotor. -150.2905.20 1-piece slotted 370mm front rotor. -150.2919.32 M-Sport (blank) 2-piece 345mm rear rotor. -150.2920.32 slotted/perforated 2-piece 345mm rear rotor. -150.2919.20 1-piece 345mm rear rotor. -150.2920.20 1-piece slotted/perforated 345mm rear rotor. It's interesting for the front rotors the description only say slotted and not slotted/perforated like the rears. The drawings clearly show the rivets between the 1-piece and 2-piece versions. Maybe I read your question a few posts back wrong. Even though the Hella/pagid and Zimmermann 2-piece attachment style doesn't look like the aftermarket ones (like Stoptech ARK), the hat does look to be a lighter material (like aluminum). I'll double check with a magnet when I get home later. |
03-15-2018, 01:44 PM | #10 | ||||
246
Rep 483
http://www.racingbrake.com/Two-piece...S40-p/2158.htm It's an e90 2piece and it's 348x30 but its lighter than the ecs 340x30. I wonder if they were to make a proper 340x30 if it would be even lighter than 19.3lbs and if so and if they were to make a 370x30 then it should be lighter than 24lbs. I exchanged emails with them but they said they were reluctant to make the 340x30 2-piece but might make a 370 |
