E90 LCI Heated Seat Retrofit
03-12-2018, 11:24 AM | #1 |
96
Rep 398
Drives: Merc, VW, Porsche, Suzuki
Just need a quick steer on my heated seat retrofit plans... I had assumed that I would need to remove my existing start/stop switch, and replace that switch panel with the heated seat one... like this (not mine):
But I see some of the later cars have this set-up: With that later set-up, what heppens to the switch panel with the start/stop switch? So as my car is April 2010 (E90 LCI), so which one should I go for - or doesn't it matter? |
03-12-2018, 11:43 AM | #2 |
456
Rep 2,749
you can use both
lower switch panel is kept if it already exist
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
03-12-2018, 12:48 PM | #3 |
96
Rep 398
Thanks for the info
03-13-2018, 04:07 PM | #4 |
96
Rep 398
Heated seats in & working - and very nice they are too. One thing regarding coding of these. They didn't work with simply adding $494 to the VO of the car, I needed to change one of the 'sitzheizung' parameters in the JBBF module to 'aktiv' instead of 'nicht_ackiv'. That did the trick & now they work perfectly.
ChawenHalo68.00 |
03-14-2018, 04:03 PM | #5 |
840
Rep 1,993
Drives: F30 335d
When you added the $option to the vo, did you then code the JBBF? In ncs expert, you would run the sg_codeiren job. This should have enabled seat heating.
It sounds like you did it manually. |
03-17-2018, 06:46 AM | #6 |
96
Rep 398
I did run the sg_codieren job, but the seats still didn't work - hence the investigation of the JBBF module.
