03-04-2018, 02:46 AM | #1 |
4440
Rep 5,733
Drives: '24 iX50; '23 i4 M50
X4 M40i Exhaust
Hey guys--My wife and I (her car) picked up an '18 X3 M40i in January, but I had a question for you folks here regarding the exhaust. Upon cold startup, does only one of your exhaust pipes emanate smoke? I understand it's to warm the cats quicker, but it bothers me (too much time on my hands I guess lol) as it looks like my other pipe is nonfunctional or broken. I recall the old days in my previous E90s, you could zip tie (or unplug in the trunk) the one vacuum hose to keep both flaps constantly open. The additional sound would be an added benefit. Prior to the X3, my wife had an F15 X5 with the M Performance Exhaust, and both flaps were open at startup/all the time.
Here's my Thread inquiring about this over on the G01 subforum--but little feedback: http://x3.xbimmers.com/forums/showthread.php?t=1452260
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
03-04-2018, 02:45 PM | #2 |
233
Rep 395
Drives: 2022 X4MC - Marina Bay Blue
I am not familiar with the G03 (X3 M40i), but I can tell you how it works on the F26 (X4 M40i). Keep in mind we have different motors (B58 vs N55), but I wouldn't be surprised if BMW left this unchanged on the G03.
To check this, take a look at under the car, behind the driver's side rear wheel. You will see the exhaust pipe has a valve that close and open the exhaust flap. You should be able to press firmly on the lever and by doing so open the valve. It is spring loaded and takes a firm press to move. If you want it to stay open (for better sound), go to the trunk of the car. On the driver's side, you probably have a hard cover that is easily removed to gain access to some electrical modules (radio?) Now look towards the very rear of the car and you should see a small solenoid attached to the chassis with a rubber mount. It will have two vacuum lines and an electrical connection. To leave the exhaust flap open whenever the motor is running, disconnecty both vacuum hoses from the solonoid and connect the two hoses with a male/male vacuum connector, bypassing the solonoid altogether. I found that a common garden sprinkler connector also works. Whenever the motor starts, vacuum is sent straight to the valve and it will open - and stay open. On the X4, engaging sport modes does not automatically open the valve. It seems the valve opens when the solonoid receives a signal from the computer at some point when the motor is asked to produce max, or near max, power.
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
