02-27-2018, 12:48 PM | #1 |
1517
Rep 3,560
Boiler is choice
Always gone for WBosch in the past but other offer longer warranty periods, Ideal for example offer 7 years compared WB 5 years.
Efficiency seems similar as do outputs. Any thoughts? Also would an internal pipe run from meter to boiler lose pressure? With 28mm copper pipe. How does the length of pipe and number of bends reduce the pressure? |
02-27-2018, 12:54 PM | #2 | |
4280
Rep 7,703
My plumber recommended it and it hasn't missed a beat (touch wood). He hasn't even serviced it, said not to bother. He's a friend of mine and says it's unnecessary for the first few years, and if anything goes wrong he'll back date the service records. |
02-27-2018, 12:59 PM | #3 | |
382
Rep 484
02-27-2018, 01:05 PM | #4 | |
951
Rep 1,643
We fit Vaillants, and at the moment if fitted by an Advance installer you will get up to 7 years on the EcoFit and EcoTec Plus range, or for £180 extra you can take this to 10 years, IMO is a no brainer. An internal pipe run shouldn't be an issue if sized correctly, all depends on what type of boiler and size you are going for. We never do any external gas runs as they look awful so always run internally. A elbow is the equivalent of adding on 0.5m It's important that they are regularly serviced, they have a gas to air ratio which if it's incorrect due to poor maintenance can cause major problems down the line. They have burner seals and other important components that can deteriorate that should be inspected on a annual basis. Only the other week we had to replace a boiler that was only 8 years old due to not being serviced, had it been done then she wouldn't have needed a new boiler. Last edited by EvilDrPorkChop; 02-27-2018 at 02:34 PM.. |
ajfoggy1517.00 |
02-27-2018, 01:33 PM | #5 |
6425
Rep 8,501
Vaillant.
We've had our ecoTEC for 7 years so far and it's only needed a replacement pressure sensor which was quick and cheap to replace by a local heating engineer (who we know). Our old Potterton had gone through two PCBs in the same timeframe. My mum has a WB combi in her bungalow and the heating system needs regular pressure top-ups. That's enough to make it a no from me.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-27-2018, 01:37 PM | #6 | |
1882
Rep 7,000
Herr Dreier381.50 |
02-27-2018, 02:13 PM | #7 |
1517
Rep 3,560
Cheers for feedback, when the whole house job was quoted it was quoted with WB but they have mentioned the pressure at the boiler might not be good enough for the WB and that a baxi or ideal would be more suited if the pressure is lower... would that make sense???
or is just a way to fit a cheap boiler? I was being drawn into the ideal with a 7 year warranty on it, but some comments above have put me off now. I wouldn't imagine the pipe run would be more than 25-30 metres inc elbows with the 28mm pipe. |
02-27-2018, 02:15 PM | #8 |
130
Rep 1,534
If you get a Worcester Bosch boiler installed by one of their registered installers and serviced regularly you get a 10 year warranty with it.
02-27-2018, 02:32 PM | #10 |
4280
Rep 7,703
Maybe, I know nothing about boilers. He said for first few years nothing would really wear or break, so start servicing after 4 or 5 years.
He wasn't advocating never servicing them. Like I said, he's a friend of mine. He said that in his own experience when a boiler is serviced in first couple of years I'd just be paying him to look at it for half an hour. No reason to lie, I was happy to pay for servicing. |
02-27-2018, 02:43 PM | #11 | |
1517
Rep 3,560
02-27-2018, 02:51 PM | #12 | |
440i Gran Coupe, Auto
877
Rep 1,295
My company predominantly installs amd maintains commercial boilers but if we do carry out a domestic job we always fit Worcester were possible. If fitting the boiler on an old system, its particualry important the installers thoroughly power flush the heating system and fit a magnetic dirt filter (Fernox TF1s are good). The will also need to dose the system with corrosion inhibitor on completion. https://www.plumbworld.co.uk/fernox-tf1-compact-filter-93-32269 |
02-27-2018, 02:54 PM | #13 | |
951
Rep 1,643
A 28mm gas pipe should be more than adequate for most combi boilers over a long run (22mm you can go a long way!), however without knowing exact measurements it's hard to say. Different manufactures allow you different tolerances on pressure drop at the inlet, Worcester do have a higher reading at 18mbar. Some other manufactures will allow you lower than this. |
02-27-2018, 03:13 PM | #14 |
759
Rep 1,863
You should service a boiler annually to check at the very least it’s functioning correctly. A fault could be fatal.
I’d also reckon, if something is going to break, its quite likely to happen in the running in period so a first service imho is vital. As for which boiler, unless the exact model is still available many years on, warranty is all you can pin your hopes on. My Potterton is still going strong at 27 years old. Now watch me freeze my a55 off next week when it dies.... |
02-27-2018, 04:25 PM | #16 |
Fool
1857
Rep 3,542
We don't have a boiler but when I was considering getting one, I was very much looking at Viessmann. When I was looking you could get something like a 20 year warranty for £250 and their boilers were full of intelligent tech and had stainless steel heat exchangers. They seemed to be the Miele of boilers on the face of it.
I have zero experience however.
02-27-2018, 10:02 PM | #17 | |
1517
Rep 3,560
I'm guess that 35kw is equal to maximum watts it can output to the radiators and I have calculated the rads roughly to 20000 or 20kw, if my thinking is right it should be good enough??? |
02-27-2018, 10:28 PM | #18 | |
1517
Rep 3,560
Now realised how mis-leading all these companies are stating hot water kw and not central heating kw in the product names, it's a minefield to work out what you need and what you are getting!! |
02-27-2018, 11:46 PM | #19 | |
877
Rep 1,295
Worctester on their website have an interactive guide to selecting your boiler which is easy to use. For a 35kW boiler you will typically need a 28mm gas supply from the meter. Possibly even bigger if its a long run from the meter and serving other gas appliances i.e. gas fires or gas hobs. However, 28mm would typically suffice. How far away is you gas meter from your boiler? |
02-28-2018, 12:22 AM | #20 | ||
1517
Rep 3,560
I have counted 19 radiators on the plans. Three being towels radiators but they'll be the source of heat for the rooms so need to be decent. |
02-28-2018, 01:33 AM | #21 | |
877
Rep 1,295
Is it 28mm now or is the companies pricing the install telling you the existing needs to be increased to 28mm? |
02-28-2018, 03:52 AM | #22 |
8790
Rep 12,257
I used to work for the company that make Vaillant and Glowworm. A bit out of touch these days but it was the case that the different models were built in different factories depending on type and not brand - so a GW from one factory may be better built than a Vaillant from a different factory....
I have a Worcester Bosch... |
ajfoggy1517.00 |
