N54 tune with Pure stage 2 DDs - anyone?
02-26-2018, 06:30 PM | #1 |
Rep 15
I am looking for someone/car shop who knows how to tune/flash a N54 after installing Pure stage 2 DDs turbos. The shop I take my car to feels confident about installing the turbos but are not sure how to tune or where to get the tune done after the install.
FYI...I have procede installed already so if anyone knows if procede+pure stage 2 turbos will work, that will be awesome but I can take out the procede if needed. I am looking to generate more whp with the upgrade (450-500 range). Currently I have cone air inlets, fmic with chargepipe and down pipes. Thanks for your help! |
02-28-2018, 06:47 AM | #2 | |
Rep 23
Reach out to (feuer) he may know someone. |
greenmachine1.00 |
02-28-2018, 10:33 PM | #3 |
380
Rep 1,497
Contact performance solutions out in Schumburg. They have a dyno u can rent and get a dyno tune from Brian may
greenmachine1.00 |
03-01-2018, 07:12 AM | #4 |
4276
Rep 9,209
Green machine is 400 miles away from Chicago IL. I don't think it will work
03-01-2018, 09:04 AM | #5 |
380
Rep 1,497
03-01-2018, 09:29 AM | #6 |
4276
Rep 9,209
From the post I'm under the assumptions that he is looking to go to a shop. Online services are available yes. He will need to do logs, send them in etc etc.
03-02-2018, 12:18 PM | #8 |
Rep 15
Thanks for the information mojobmw_e90! Turns out that my shop had questions about using my existing procede with the new turbos. I sent an e-mail to procedetuning which has now become openflashperformance (maybe? it is not clear from their website) and got no reply. The shop techs also tried to send e-mails. We have not heard back. So at this point it might mean taking the procede out. My shop is looking at using Cobb with the Pure turbos.
03-02-2018, 06:46 PM | #9 |
Rep 15
feuer - is it possible to tune the procede for use with the pure stage 2 DDs? If so, can a place like Performance Tuning in Schaumburg help with this?
03-02-2018, 06:53 PM | #10 | |
Rep 15
2) What application do I have to run on the laptop connected to the car? 3) If a dyno is needed for tuning, and I have to rent it, I am assuming I have take the car over to where the dyno is at? How else will it work? As you can tell, all this is very new to me, trying to understand the basics...thanks! |
03-02-2018, 07:27 PM | #11 | |
380
Rep 1,497
03-02-2018, 11:16 PM | #12 | |
4276
Rep 9,209
03-03-2018, 10:17 AM | #13 | |
Rep 15
03-03-2018, 10:21 AM | #14 | |
Rep 15
03-03-2018, 10:38 PM | #15 | |
4276
Rep 9,209
03-03-2018, 11:27 PM | #16 |
43
Rep 351
AFAIK, Procede is superior unit to JB4 hardware wise but it doesn't have any support from Openflash or Shiv. so you are on your own. You would change to auto-tune through the procede software interface using a laptop and connecting the usb cable. Autotuning was set to off for later version of the procede maps.
It would be in your best interest to remove the procede and go full MHD or JB4+MHD and get a custom tune.
09 e82
BIG THANKS TO LEVANIME FOR ALL THE HELP |
greenmachine1.00 |
03-04-2018, 11:51 PM | #17 |
26
Rep 86
Ditch the procede
Flash only with MHD or JB4 + BEF Tuning can be done remotely & fine tuned on a Dyno if need be or you have a desire to do so. Assuming you are capable of taking clean logs, an e-tune should be simple & a base map can be sent prior so you have something to use b4 the car leaves the shop. Not sure how or why this is so complicated 😂 |
03-07-2018, 07:48 AM | #18 |
Rep 15
midwest_xi - I guess for those of us who have done this before and have a car shop that is experienced with this stuff, it is not complicated. Thanks for all the inputs, it really helps. You sold your pure turbos after ~14k miles, right? I am looking at getting the same...anything I should know/watch out for before I go ahead with them for my n54? I don't plan to drive too hard all the time...I am looking for something that is fun to drive but also reliable.
03-07-2018, 07:54 AM | #19 |
Rep 15
I like this idea! I talked to my technician about doing this. I don't plan to drive too hard anyway, at least not all the time. Even with just the procede tune in map 2, my rear wheels sometimes lose traction in 2nd gear...so I am not sure how additional power can be kept down...need better tires maybe? I have continental contact sport on right now.
03-07-2018, 09:06 AM | #20 | |
4276
Rep 9,209
greenmachine1.00 |
03-15-2018, 10:15 AM | #21 |
Rep 3
The Procede was a great tool, I still have one in my spare parts bin. Get team viewer and I can help you get it to where it needs to be. It's a bit more complicated to make it work with port injection, it's doable.. but you would have to drive to my shop for all that
feuer4275.50 |
Tags |
flash, n54, procede v3, pure stage 2, tune |
