02-25-2018, 07:00 PM | #1 |
641
Rep 1,381
Warped rotors?
They're less than 3 months old with brand new Pagid pads.
https://streamable.com/1e6gx I've had them off, cleaned down and sanded the pads flat again but it's made no difference.. I'm now considering getting them resurfaced possibly? What's everyones thoughts?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-26-2018, 06:39 AM | #3 | |
641
Rep 1,381
I do believe there was also a pretty substantial line put into the back of one disc from a stone.
2015 435i - 401whp
02-26-2018, 11:19 AM | #4 |
481
Rep 1,572
Normally, warped rotors will cause a noticeable vibration under moderate to hard braking. I watched your video and see the issue. Have you checked the rotor are mounted securely and not wobbling/loose? Only way to be sure, is pull one and have a shop check it. If you will have enough meat left on the rotor after turning them, that is an option.
03-04-2018, 06:40 PM | #6 | |
641
Rep 1,381
The rotor is completely clean, I'm guessing there must be a tiny amount of run out.
2015 435i - 401whp
03-04-2018, 07:39 PM | #7 | |
2966
Rep 6,003
03-05-2018, 07:16 AM | #8 |
8245
Rep 16,088
The rotor could stay clean because it's constantly wiped clean by the pads. There should be evidence on whatever it's rubbing against. I don't know what caliper anchor bolts you're referring to, but the calipers shouldn't be locked down tight. They're supposed to float on the caliper guide bolts.
03-11-2018, 06:28 AM | #9 |
238
Rep 878
You need to pull the rotor and see/make sure that the surface behind is completely flat and free of dust/dirt.
03-11-2018, 07:02 PM | #10 | |
641
Rep 1,381
Yeah I went through this on both sides, one admittedly did have a nasty score from a small stone on the inner side of the disk however they're all completely clean now.
2015 435i - 401whp
