02-24-2018, 12:32 PM | #1 |
12
Rep 8
M5 display
hi
im a newbie in coding, only been using Bimmercodeapp a couple of times. Is it possible to code the display so it will look like the new m5 ? |
02-25-2018, 04:48 AM | #2 |
186
Rep 235
I assume it would be possible. Have a look under dkombi2 in 'Expert Mode' and see if there's anything that looks like it could enable the M5 display.
For example the alpina display is ALPINA_ENABLE and needs set to active. I will have a look when I get the chance, but will probably be a couple of days as I'm busy with other things. I didn't even consider looking into changing to the M5 display as I have a diesel and assumed the rev counter scale would be too high. |
Osheatwo205.00 |
02-10-2020, 05:37 AM | #6 |
105
Rep 335
I also wonder this. Also enabling any additional addons to HUD (turnlights, rev gauge, shift lights, etc.)
2017 G30 520 (1.6lt)
2016 S1000RR 2014 W205 |
02-10-2020, 09:33 AM | #7 |
Rep 5
02-10-2020, 11:08 AM | #8 |
7859
Rep 5,796
Drives: 2024 BMW XM Label
I have the the full digital cluster and that option is not presented like the Alpina display (which is the one I use now) or the others.
02-10-2020, 11:11 AM | #9 | |
Rep 5
02-10-2020, 11:16 AM | #10 | ||
7859
Rep 5,796
02-10-2020, 11:23 AM | #11 | |||
Rep 5
FlyingWombat243.50 |
04-15-2020, 02:29 AM | #13 |
Rep 3
Is it possible to code the ///M start up animation with DKOMBI2
like shown at 0:24 in the following youtube video:
Thanks in advance! |
05-12-2020, 10:29 AM | #14 |
14
Rep 21
So far I have not seen that coding option available on standard dials. Might be the same, reserved only for M5 hardware, which is different from regular 6WB.
05-17-2022, 04:02 PM | #17 |
1716
Rep 1,636
You can code the "M" startup onto I drive 7, and add the M Sport gauges, but there's nothing I've seen to code Live Cockpit to a "M" startup, or change the gauges to M5 ones.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
06-15-2022, 12:30 AM | #18 |
2374
Rep 8,364
07-13-2022, 04:31 PM | #19 |
78
Rep 66
Drives: BMW G30
This should do the trick!
07-13-2022, 09:30 PM | #20 |
176
Rep 305
07-13-2022, 09:34 PM | #21 |
78
Rep 66
Drives: BMW G30
Oh man! Yeah unfortunately a few months back I fried my bdc. Had to get a new one and recode with new updates. Alot has disappeared unfortunately. I haven't updated my headunit for this exact reason.
12-04-2023, 05:07 PM | #22 |
Rep 1
