BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > 2fa3 code after updating egs transmission module
      02-21-2018, 08:55 PM   #1
N54_e90
Don
46
Drives: '09 E90 335xi Family Sedan
I was able to successfully update my transmission egs module following this thread:
http://www.bimmerfest.com/forums/sho.../621988?page=1
Daten files and winkfp installed via bimmergeeks.
After successfully updating i took the car for a quick spin and noticed an immediate improvement. No codes or anything.
Then i decided to reset all adaptions in inpa and i got a 2fa3 coding missing. Had a cel but it went away after a bit of driving.
I no longer have a cel but the code keeps coming back in inpa after clearing (again no cel illuminating). Car runs and drives great.
Any thoughts?
      02-21-2018, 09:51 PM   #2
Sensible_
529
Drives: 2008 E90
Any thoughts?
Seems like it can happen:
http://www.1addicts.com/forums/showthread.php?t=1193909
Try key cycling. If not working run the test plan with ISTA and replicate with winkfp / NCS if required.
      02-21-2018, 10:12 PM   #3
N54_e90
Don
46
So clear fault, reset adaptation? Unplug key the plug back in with ignition on and check for fault? Should I do this in MSV80 or MSV70?
Thanks
      02-22-2018, 03:19 PM   #4
Levanime
BimECU
Levanime's Avatar
193
Drives: BMW
2007 BMW 335  [0.00]
Default code it
      02-22-2018, 05:52 PM   #5
N54_e90
Don
46
got it sorted, thanks for help guys
      07-18-2018, 01:36 PM   #6
rkreimer10
12
Drives: e46
Glad you got it sorted, but would you care to share what exactly the fix was.
      07-18-2018, 03:23 PM   #7
Impac
21
Drives: Bmw
Egs needs to be default coded after update, and if you have paddle shifters dsc needs default coding also
