M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Increasing tire size from 245/265 to 255/275: any cons ?
      12-21-2016, 05:38 AM   #1
chrismac
Addiction
chrismac's Avatar
39
Drives: BMW E91 M Sport Plus Edition
Thinking about putting some winter tyres on stock rims. Would 10mm wider fit? There are more choice.
Thanks.
      12-21-2016, 07:56 AM   #2
David@ActiveAutowerke
BimmerPost Supporting Vendor
813
Drives: M2
Yes, they'll fit without any issues.
      12-21-2016, 08:15 AM   #3
chrismac
Addiction
chrismac's Avatar
39
Thank you
      12-28-2016, 01:44 PM   #4
fusion0389
141
Drives: 2016 328i xDrive M Sport
will that small difference in diameter throw off the ESP, diff, speedometer?
      12-28-2016, 03:10 PM   #5
zenmaster
1577
Drives: '17 M2
Why would the diameter change at all?
      12-28-2016, 03:28 PM   #6
nd2002
nd2002's Avatar
179
Drives: 2017 M2
255/275 refers to width of the tire.
      12-28-2016, 06:50 PM   #7
BruceM
985
Drives: '17 6MT MG M2,930,Jag XKR 5.0
Why did BMW not make the stock widths 255/275, I wonder?? I also wonder whether I could fit those on the stock wheel with a one-inch drop and 10 mm spacers....
I've got Contis, and I am going to beat those babies up so that by summer I can bullshit myself into thinking I need new tires
///M TOWN16074.00
      12-28-2016, 07:15 PM   #8
Caduceus
Australia
342
Drives: 2008 135 (sold), 2017 M2
Assuming the same profile, an increase in width also brings a corresponding increase in sidewall height.
35 series tyre. 10mm more width = 2x3.5mm = 7mm increase diameter.
And to answer the previous question....no it won't cause issues with DSC or LSD function. There will be a minor change in speedo which will more likely then not make it closer to a true reading. With the OEM MPSS tyres, 100kph indicated equals 98kph GPS.
That's the theory. In reality, different brands and models of tyre may or may not measure exactly what is printed on the sidewall. YMMV......literally.
Appreciate 6
      12-28-2016, 07:37 PM   #9
zenmaster
1577
Drives: '17 M2
I always thought the diameter remained constant, regardless of the aspect ratio / sidewall length.
      12-29-2016, 06:45 AM   #10
fusion0389
141
Yes and no... The diameter of the tire changes even when the only parameter changed is the width. So yes, 255, 275, refers to the width of the tire, that is understood. However increasing the width of the tire from 245 to 255 or 265 to 275 does increase the overall diameter of the tire. I took a snapshot of the differences between Michelin Pilot Super Sports. The top one is stock tire size and the bottom is one size. As you can see yes the tires are most definitely wider as expected, however overall diameter has also increased along with a change in revs per mile which will throw off your speedometer, odometer, and possibly ESP depending on what parameters the program monitors. If BMW has a way to manually change the revs per mile in the M2's computer, that will ensure the car is operating as it should with the modified tire size. Obviously, the difference is small, I would hope the BMW programming would be forgiving with such a small difference in diameter and smart enough to compensate appropriately.
Appreciate 3
      12-29-2016, 11:56 AM   #11
BimmerSpain
BimmerSpain's Avatar
Spain
82
Drives: Coming Soon Bmw M2
And the sizes 255/275/35/19 are compatible with the Coilovers???
Any experience??
I'm thinking to put this sizes on a BBS CI-R et 25 and 35 with a Kw V3...
      12-29-2016, 06:28 PM   #12
Twt
Twt's Avatar
634
Drives: 2017 M2
You will need to test fit anything other than stock sizes. I am putting MP coilovers on my M2 next week, lowering the car, changing the rake and then corner balance.....then check clearances again to see what will fit. Remember that all 255/275 are not created equal....tires can vary a lot between different manufacturers. Also, front camber will effect fit.
      12-30-2016, 07:19 PM   #13
Norcalmav23
Norcalmav23's Avatar
292
Drives: AW DCT M2
I dug around the forums like crazy a few months ago to answer this question. There was actually a guy that went 265's in the front and 285's in the rear and had no issues. That is the route I will be going, no spacers.
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough
2008 VW GTI - first experience with boost
97 Integra GSR - crashed it
      12-30-2016, 08:33 PM   #14
CommitConfirm
475
Drives: The Bus
Diameter (of the rim), yes. Circumference, no.
      12-30-2016, 11:57 PM   #15
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by Norcalmav23 View Post
I dug around the forums like crazy a few months to answer this question. There was actually a guy that went 265's in the front and 285's in the rear and had no issues. That is the route I will be going, no spacers.
I would make sure to stick with the same brand and model tire. Rock on..
///M TOWN16074.00
      12-31-2016, 01:04 PM   #16
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks.
I'm running 265/35 r19 winters up front and square. It's fine...I think the rule of thumb is if you want 275's up front you'll want a 10" wheel so the sidewall leans in a bit and camber plates.
I've had 265,275's mounted on the front. The 275's won't rub with a 30 sidewall. They tend to rub on the plastic liners first. So a 275/30 would actually be a better fit then than a 265/35. I'll be going 265/35 up front because I want that extra sidewall. I don't mind a little liner rub.
Out back a 285 makes the most sense. I'm thinking there's no reason why a 295 wouldn't fit or even a 305 with the right offset. I had 315/30 Hoosier r7 slicks mounted and they are too pudgy with a 10" wheel. Anything bigger than a 295 you'll have to be exact with your measurements and offsets. More suited to a high offset 10.5 or 11
Appreciate 2
      01-01-2017, 12:48 PM   #17
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
Thanks.
I could be wrong, but wouldn't you want NARROWER tires for the winter?
-c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock
2008 Acura RDX-stock
2005 Honda S2000-mostly stock
1994 Nissan 300ZX Twin Turbo-barely stock
Appreciate 4
JTO245271.50
hAxel91.00
///M TOWN16074.00
      01-01-2017, 06:06 PM   #18
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks.
-c
Correct I couldn't find decent sizes, couldn't pass up the 265's
Appreciate 2
pup73516.50
Hxngs176.00
      01-02-2017, 12:11 AM   #19
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
What brand of tires and wheel offset? Suspension mods? How much rub if any? Sorry for all the questions but am very interested in doing this. I have about -3 camber and would like to put on ET27 or 25 offsets with 265/35s.
      01-02-2017, 04:49 PM   #20
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
-3 camber up front? If that's the case you can run a 275/30, a 265 won't be an issue. Suspension is H&R sports. 12mm spacers up front and 7mm out back on stock wheels. No camber plates yet so stock camber. Tire brand is Bridgestone, they are winters so the tread adds some height I assume.
When I have my wheels built it'll be close to those specs. 19x10 square et 32-36, haven't decided yet but I'll be running them with the spacers since they won't have centercaps, the turner hub-extenders hide the hub rust when running Open lug racing wheels.
So final specs with spacers will be right around 19x10 et 22-25 front and et 28 rear. I still have a little room out back with this setup and camber plates up front would give me 5mm or so of extra wiggle room.
Pyrat 21417.50
      01-03-2017, 12:12 AM   #21
chris719
7332
Drives: '08 M Roadster
No, unfortunately it does not. Plug some in here and check:
http://www.1010tires.com/Tools/Tire-Size-Calculator
The overall diameter increases with every step up in width. For 245->255 the difference is not really going to disturb anything though. Once you get 20 or more away you should see if dropping the aspect ratio brings you closer to the stock diameter.
      01-07-2017, 11:05 AM   #22
Pyrat 2
Pyrat 2's Avatar
1418
Thanks! Helpful.
Wanting 265/35 instead of 275/30 because I'm looking for some extra rubber between the ground and the wheel. My concern has been rubbing with the fender liner in front near the inlet duct. Clearance is very tight even with the stock wheels when they are turned and I want to make sure that the larger diameter doesn't rub there. I'm not concerned about inner rub with the strut or outer rub with the fender (because of my camber).
I too will be going with the Turner extenders. My wheel on order are 35 offset and was looking at either the 7.5 to 10mm extenders giving me a 27.5 or 25 offset. My rear offset will be 35 with a 265 or 275/35-19 tire.
m2
