02-19-2018, 06:11 AM | #1 |
3510
Rep 2,044
Pls Post Front Camber #s....
Hello BMW Experts!
My almost new car has almost straight up, -0.1 front camber, both sides. Seems a little upright to me. Do folks knock out the two pins on the top mount on F30s for a bit more adjustment? I've seen those lower lateral links...at ~ $180. per side. Pls post your numbers! TIA! Murf Last edited by Littlebear; 02-19-2018 at 03:28 PM.. |
02-19-2018, 05:40 PM | #2 |
850
Rep 2,771
Depends on what you're going for. Most ppl on this forum don't add any additional camber unless they're tracking their car or stancing them. If you drill out the camber pin you can get up to -1. If you replace with M3 front control arms you can get up to -1.5. But camber plates are your best bet for full adjustability up to -4 depending on what you plan to do.
I run -2.4 front and rear with absolute 0 toe and have no issues. Ran something very similar on my previous e92 and got 40k miles out of those tires after flipping them twice. I'm on about 10k with these and will be flipping them when I get my full brake job completed in April. My previous e92 at -3 and stretched tires all around for shits and giggles. |
02-19-2018, 06:14 PM | #3 |
3510
Rep 2,044
Hi NO,
More to the point, I'm wondering how "normal" my car is (I see no bent arms; both sides read the same). Maybe I'm just surprised that the camber is spec'ed to be so straight up compared to past 3-series sickle-based front ends. Murf |
02-19-2018, 06:33 PM | #4 |
824
Rep 1,584
My car was set to -0.1 degrees front camber from the factory as well (340i w/ M Sport & Track Handling Package). So far I haven't done much about it aside from lowering the car a bit and keeping the natural camber I gained by doing so. I'm at around -0.5 degrees now up front with toe set close to zero (very slightly toe'd in).
02-19-2018, 09:59 PM | #5 |
850
Rep 2,771
Yea, that's how they come from the factory across the board. Drill the camber pin out and push the strut over for -1 and get the toe dialed in on your next alignment. Easy peasy lemon squeezy. Lol
02-20-2018, 01:04 PM | #6 | |
824
Rep 1,584
If someone has tried this on the F30 w/ 5-bolt top mount, let me know and I'd be happy to give it a shot on my car. |
02-20-2018, 03:47 PM | #8 |
3510
Rep 2,044
I agree with Remonster,
All of the bolt holes look very precise, with no slotting or oversizing. So you have to slot them yourself (not)! Murf |
