App for logging / measurements
02-16-2018, 06:45 PM | #1 |
Rep 15
Hi all,
Just wanted share an app I came across other day called Deep OBD for BMW and VAG. It uses the same ECU files as edibas to interrogate the ECU so lots of logging options. Its also open source which is cool! One drawback is you need to know the ECU Job / Result names and what data they correspond to! and makes it a little harder to use. I was able to convert the ecu file used by edibas so that you can view all the available jobs and results. I have attached them to this post. Each result has a comment which although in German can help point you in the right direction. I have started collecting some of the main ones (lambda, temps, adaptations) into a spreadsheet below. If anyone knows or finds any others please post them. https://docs.google.com/spreadsheets...it?usp=sharing Hopefully be of use to some Last edited by sbains84; 02-16-2018 at 07:02 PM.. |
