F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > TPS in Canada
GetBMWParts
      02-16-2018, 11:57 AM   #1
crank73
14
Drives: 428i
TPS in Canada
All,
I'm looking at buying tire/wheel setup. I know that in the States they have TPMS with sensing valve stems and in Canada we have TPS. Can someone confirm that the TPS system in Canada needs no special stem in the wheel? In other words, any wheel / tire combo (correct size of course) will work as Canadian BMWs measure the circumference externally and I don't have to have special gadgets in the wheel that I need to make sure I have installed from the seller or need to remove from my current setup and install in the new setup.
Thanks
      02-16-2018, 01:37 PM   #2
M2Rush
83
Drives: 2014 BSM 335i x-drive
Correct, no need for TPMS sensors. The Canadian version uses the ABS system to measure rotational differences between wheels. I believe if they all go down, you will not get a notice.
thug10820.50
      02-16-2018, 07:06 PM   #3
TheUltimateDrivingManiac
Freude am Fahren.
835
Drives: F15 X5 xDrive35i
No sensors by default, but you can order them with 2VB option. So check that you don't have it.
Freude am Fahren.
      02-17-2018, 09:42 PM   #4
crank73
14
Drives: 428i
Ok, good. Just wanted to make sure. Thanks guys.
f30post
