23k on the runflats
06-02-2008, 07:03 AM | #1 |
1868
Rep 13,043
Drives: BMW M340I G20
23k on the runflats
All tyres need changing, but the two fronts have gone the same way.
Company 320d Saloon, not mine. |
06-02-2008, 07:04 AM | #2 |
Rep 80
Drives: '12 E91 318d & '16 F46 220d Xd
that must slide some in the wet
TimsterC
2012 E91 318d ///MSport : Titanium Silver : Towbar : Privacy Glass 2016 F46 220d xDrive Sport Gran Tourer B47 2.0d : Medeterranian Blue : Towbar : Privacy Glass |
06-02-2008, 07:10 AM | #3 |
1868
Rep 13,043
06-02-2008, 07:18 AM | #4 |
Rep 283
Drives: E93 330d M Sport Auto
23K on runfalts ain't bad.
I changed mine about 11K ago and I reckon they have another 10K left in them. B Potenza's All 4 had pretty even wear - I found this surprising and thought the rears would have been in poorer condition Did you go for Michelen, Bridgestone or other. Quite a few on E90Post seem to prefer the Michelen RFT for their ride quality PhilR |
06-02-2008, 07:23 AM | #5 | |
1868
Rep 13,043
06-02-2008, 09:32 AM | #6 |
75
Rep 2,937
I did 40,000 on my rears and 44,000 on the fronts. The fronts went exactly as your picture. The lease company refused to change the front with the rears as they still had up to 5mm in the centre of the tyre. Once the casing started to show they had to replace as they are not only illegal they are down right dangerous. Two days after changing the fronts I had to hit the brakes on hard on the M6. I stopped instantly, the Merc behind had no chance and hit the rear. If I hadn't of had the tyres change I am sure I would have hit the car in front and I would be having an interesting conversation with the lease company and insurer!!
BMW claim the wearing of the outside of the tyre is due to me not keeping my tyres inflated correctly. Aparantly I should check pressures every week. The tyre depot claims most 3 series wear like this!! PS the damage shown on my avatar on the front of my car was from hitting barriers twice after the Merc hit me! |
06-02-2008, 09:41 AM | #7 |
1868
Rep 13,043
06-02-2008, 09:56 AM | #8 |
112
Rep 2,333
Yep my E90 wore like that and the E92 is goin same way....given that we have tyre pressure monitoring systems, why should we check them every week???????
Current: F13 640i MSport, e85 Z4 3.0i
Previous - Alpina D3 BiTurbo E90 LCI Manual, 320d M Sport E92 Auto, 330i M Sport E92 courtesy of BMW UK....320i M Sport E92 Auto, 320d SE E90 Manual. |
06-02-2008, 10:11 AM | #9 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
06-02-2008, 11:05 AM | #10 | |
75
Rep 2,937
Do not trust TPM. Do not trust that run flats keep their pressure. You can't tell they are low due to being RFT!!!! |
06-02-2008, 11:18 AM | #11 | |
Rep 283
I've had a puncture and it notified me immediately - I took a look around the car and couldn't tell which one was the culprit. Pulled into a garage and checked the pressure's and the FSN was down tp 23PSI. I had a leaking valve and over a few weeks a tyre dropped to 32PSI - Monitor did not detect this......odd? PhilR |
06-02-2008, 11:18 AM | #12 | |
1868
Rep 13,043
Out of interest the TPM can only tell if there a difference between wheels and if two on the same theoretical axle drop by a simular amount it won't flag a warning because it works on rolling radius. |
06-02-2008, 11:23 AM | #13 |
75
Rep 2,937
Hence the service guy talking to me like a naughty school kid about checking pressures every week
06-02-2008, 02:31 PM | #14 |
337
Rep 8,811
I did 23k on my Michelin RFTs and they still had 3k-4k of tread left when I sold the car
06-02-2008, 02:33 PM | #15 |
The Tarmac Terrorist
952
Rep 29,345
Drives: 997.2 GT3
I gp thru tyres like theres no tomorrow.
997.2 GT3
06-04-2008, 11:10 AM | #17 |
Right Responsible
58
Rep 1,646
My mate used to only get 7K on the rears of his E36 M3 evo.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
06-04-2008, 11:57 AM | #18 |
75
Rep 2,937
06-04-2008, 12:25 PM | #19 |
Rep 47
I had all four replaced on E91 320d at 19k.
Fronts had worn unevenly across the tyre, backs were evenly worn down. Lease Co made Kwik Fit replace the Bridgestones with Michelins. I had to get them to try to balance it 3 further times (once at the depot - "my van balancer can't do it that accurately") before they relented and replaced all four with Bridgestones. It is a pain in the rear not having a spare - in the past I would just swap each wheel in turn with the spare (preferably) until I found the duff one. The last fitter also echoed what has already been said that he has seen loads of 3 series on runflats with uneven tyre wear - usually replacing all four at the same time. He also claimed that mine was the second set of new Michelins he had to replace with Bridgestones in the last two weeks. Sounds like page 2 of the tyre fitters book of excuses to me. |
06-04-2008, 12:43 PM | #20 |
75
Rep 2,937
My Bridgestone rears were replaced by Michelins as the lease company prefers these (sounds like a back hander to me) However a few weeks later when the fronts had reached the casing they reluctantly gave the go ahead to replace. As Michelins were not available they put Bridgestones back on. I hate mixed tyres on a car at the best of times. In this day and age when all tyre brands say tyres should be matched it should not happen. Only had the car for a few more days until I crunched it on the M6!!!
06-04-2008, 04:08 PM | #21 |
952
Rep 29,345
Drives: 997.2 GT3
I think ive done approx 3500 on the last set and the rears are looking ready for replacement
997.2 GT3
06-04-2008, 05:08 PM | #22 | |
275
Rep 9,218
As a result the edges of the RFT's wear REALLY quickly if you don't monitor your pressures. The tyre pressure monitoring system will not pick this up because it only identifies a sudden rapid deflation. In the end there is no substitute for keeping an eye on them yourself. In reality, a weekly check is probably excessive and once a month does the job, but if you skip it you get wear as shown in the photo. |
