n55 liqui moly?
02-13-2018, 09:16 AM | #1 |
216
Rep 849
n55 liqui moly?
Hey guys.
I have a FBO n55 6mt 335i. Car has 41k miles on it. I need to do an oil change and have been hearing great things about Liqui-Moly. Turner Motor Sport has the Synthentic Longtime High-Tech Liqui-Moly 5w-30 kit for the n55. Is it worth spending the money on Liqui-Moly? Should I get it with any additives? |
02-13-2018, 10:36 AM | #2 |
New Lifetime Replacement Policy
818
Rep 11,738
Liqui Moly makes some of the finest oils for your car, High Tech and Molygen are my to go to oils from them right now for the n55.
As for additives I run Pro-Line engine flush from Liqui Moly every few oil changes. |
E92TiAg335i216.00 |
02-14-2018, 07:54 PM | #3 | |
216
Rep 849
I just did some research and did not find that Liqui-Moly Hightech was rated for a 335i, but rather a 335d. I then googled Molygen and found that it wasn't listed for BMW at all... I'm nervous to run oil that isn't "supported by BMW." Will this make a difference? Thanks in advance! |
02-15-2018, 12:10 AM | #4 |
40
Rep 177
If you are set on Liqui Moly then use Liqui Moly 2332 Leichtlauf High Tech not Synthetic Longtime High-Tech. It's BMW LL-01 certified. I run Motul 8100 X-cess and it's also LL-01 oil. I use 5w40 all year round here in California and it's great oil. The LL-01 certification focuses mostly on how well they lubricate the valvetronic system in our cars. You can run any decent synthetic but why would you want to when you can run oil that is approved by the manufacturer at almost no extra cost? I've talked to a bunch of mechanics that tell me the LL-01 certification is BS but I guess everyone has an opinion!
02-16-2018, 01:23 AM | #5 |
166
Rep 429
Drives: 2011 e92 335xi
What's the consensus about Liqui-Moly Ceratec on N54/N55 ?
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
02-17-2018, 03:51 PM | #6 |
49
Rep 220
I added some liqui-moly "Molygen 5w-30" recently for the first time and the engine is super smooth. I'd assume it's LL-01, but didn't check. The oil is green so you can use a fluorescent light to see if there are any leaks.
02-17-2018, 04:26 PM | #7 |
17
Rep 57
Drives: 2013 E92 M3
I couldn't find any LL certifications for 5W-30 molygen. I've only seen 5w-40 I think with LL-01.
02-18-2018, 09:11 AM | #9 |
49
Rep 220
