02-12-2018, 08:45 PM | #1 |
27
Rep 249
335 M Sport Suspension Fit on a 340i Sportline?
Was looking at a M Performance setup but install costs are hefty.
So looking at this option. Would the 335 M Sport suspension fit a 340i? Are the strut mounts different or something? THanks! |
02-14-2018, 08:12 AM | #3 |
518
Rep 891
Install cost between the M-sport suspension, M-Performance suspension, or any coilover setup should be damn near identical. They are all replacing the same parts, just with different grades of hardware.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
02-14-2018, 09:31 AM | #5 |
518
Rep 891
This is correct.
02-14-2018, 11:04 AM | #7 | |
3082
Rep 4,333
Also, strutmount changed from 3 to 5 bolt sometime pre lci. Just get m-performance suspension for 340i @ethan. |
02-14-2018, 11:13 AM | #8 |
27
Rep 249
02-15-2018, 11:38 AM | #9 |
550
Rep 373
Strut mounts changed on the 335i to a 5 bolt pattern around Jan 2015 production date. My '15 335 has the newer 5 bolt pattern. So - if you found a late Pre-LCI 335i suspension setup, it could be an option.
