02-11-2018, 09:42 AM | #1 |
27
Rep 249
M performance suspension fit on 340i sportline?
I’m in the mist of a full blown m performance makeover and I’m getting all kinds of confusion from dealers, web and forums on whether the m performance suspension fits on the 340i or not. Anyone know definitely?
Thanks !! |
02-11-2018, 10:56 AM | #2 | |
92
Rep 348
Easier if I have the last 7 of your vin. You will also need to replace your sway bars. I recommend going with H&R rather than the factory m sport ones. More info attached.
02-11-2018, 11:47 AM | #4 |
27
Rep 249
Do some reason when I put that part number from real Oem into getbmeparts it shows 4 series https://www.getbmwparts.com/partloca...catalogid=4462
02-11-2018, 12:20 PM | #5 | |
92
Rep 348
It is a retrofit for many different models. http://www.realoem.com/bmw/enUS/part...&q=33502409928 Sway bar kit here: https://www.tirerack.com/suspension/...kg+Non-Runflat http://www.hrsprings.com/application...s/4/1776/2016/ Kit number 72878-5 You will also need the following springs plus pads. FRONT: 31 33 6 860 631 Upper spring pad 31 30 6 791 712 Lower spring pad 31 33 6 787 114 REAR: 33 53 6 860 622 Upper sprint pad 33 53 6 764 419 Lower spring pad 33 53 6 791 709 Good luck.
02-12-2018, 03:38 PM | #6 |
27
Rep 249
So I just got a quote from a local reputable Bmw mechanic shop in OC (bullet- in case anyone knows)
They quoted me the following to install the full M performance suspension kit with front and rear sway bars (which are required if you don’t have a m sport 340i) Does $1310 sound reasonable !?? Breakdown $ 750- spring/struts and the front sway bar $ 400- rear sway bar $160 - for the alignment |
02-12-2018, 06:48 PM | #7 | |
518
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
02-12-2018, 06:54 PM | #8 | |
5886
Rep 10,256
02-12-2018, 08:31 PM | #9 |
27
Rep 249
appreciate all the help. Man I was really hoping to do this for less than $800-$900 but the whole dropping the subframe just to swap out sway bars is really destroying the pros of installing this suspension.. ugh. $1900 for the kit and $1300 to install doesn't feel right.
Tags |
340i m performace |
