Just got a 2AC7 & 3100 code after replacing VCG and PCV valve...
02-10-2018, 06:18 PM | #1 |
Rep 4
Looking for advice. Just got a 2A7C and 3100 code on my 135i after replacing valve cover gasket and PCV valve.
After I finished the job the car started up fine, ran for a couple minutes then suddenly started running rough, and threw the CEL and codes. Only thing I can think of was when I was screwing the PCV valve in, I heard a small cracking noise as I finished. Could I have damaged the PCV valve or valve cover by screwing in the PCV valve too far? Would that even cause these codes? Here's the report from carly - note that the codes for the Pre cat 02 sensor and the post cat bank 2 O2 sensor kicked in just a couple days *before* I did the valve cover gasket. Fault Report - Carly for BMW - Version: 27.60 FV ID1: 873f5943-10d0-400a-811f-c9b037b6a4c5-861 ID2: f6b76aca-c64d-497f-9ce0-875e32d2d03a-d1c-45b6 INFO: USB-MODE Base: E87 Build-Year: 2009 Faults: 6 ECUs: 16 Filter: just found Model: 1 (E81, E87) Automatic engine recognition (MotorID=86, Parameter=28) Battery: no battery info ADDITIONAL OBD: OFFNormal communication Normal connection normal C 2 Date: 2018-02-10 15:46:33 USB Device Version: 21 Device: >samsung< >hltevl< >SM-N900W8< Motor Control: Engine / Motor AfterCat 02 sensor signal at full load Code: 002C7C PreCat 02 throttle sensor, Bank 2 Code: 002C2E :Lambda probe after catalytic, electrical: Short circuit to positive / VANOS intake, cold start: not adjustable / Electronics - Lambda probe after catalytic converter / Lambda probe heating in front of catalytic converter Code: 002A7C :Boost pressure control 2 Code: 003100 ABS / DSC / Brake: Dynamische Stabilitaets Kontrolle / DSC ECU not present/no response from ECU Airbag: Airbag ECU OK, no Fault Code Transmission Control: Transmission / Getriebe GS 19 ECU OK, no Fault Code Instrument cluster: Instrument cluster / Kombiinstrument Phone failure Code: 00A554 Central info display / Zentrales Display ECU not present/no response from ECU Heating / AC: Air conditioning / Klimaanlage ECU OK, no Fault Code Immobilizer System: CAS ECU OK, no Fault Code Park distance control: Park Distance Control / PDC ECU not present/no response from ECU Sunroof / Roof: Sunroof / Schiebedach ECU not present/no response from ECU Roof / Dach ECU OK, no Fault Code Audio/Navi/Communication: Phone / Telefon ECU OK, no Fault Code Hifi Amplifier / Verstaerker ECU not present/no response from ECU Tuner Antenna / Antenne ECU not present/no response from ECU Hybrid Radio USA ECU not present/no response from ECU Digital Satellite-Tuner USA ECU not present/no response from ECU Navigation ECU not present/no response from ECU CD-Changer / Wechsler ECU not present/no response from ECU Audio-System ECU not present/no response from ECU Video ECU not present/no response from ECU Seats: Seats / Sitze ECU OK, no Fault Code Seats / Sitze ECU OK, no Fault Code Systems: Junction Box Passenger / Beifahrer Internal error of the sensor - K-LIN 6 xAUC sensor Code: 00A6CF Fuel pump / Kraftstoffpumpe ECU OK, no Fault Code Tire pressure control / Reifendruck Kontrolle ECU not present/no response from ECU Passive Go System ECU OK, no Fault Code Car Communication Computer CCC ECU OK, no Fault Code Car Communication Computer CCC ECU OK, no Fault Code Car Communication ECU not present/no response from ECU Anti-theft alarm system: Interior protection / Innenraumschutz ECU not present/no response from ECU Theft alarm / Diebstahl Warnanlage ECU not present/no response from ECU Body: Trailer / Anhaenger ECU not present/no response from ECU Fussraummodul /FRM ECU OK, no Fault Code Other: Last edited by emdubya; 02-10-2018 at 06:21 PM.. Reason: typo |
02-12-2018, 11:09 PM | #2 |
339
Rep 1,185
It's could be a hickup with the tune if you have one or the vanos got dirty. Disable your tune (if you have one) and Try deleting the codes and starting the car again to see what happens. I'd also make sure your oil is filled to good on the oil gauge (if you removed any)
