Drag Racing Advise - FBO E91 Wagon
02-09-2018, 09:17 PM | #1 |
Rep 7
Hi Guys,
Looking for a bit of advise with my car regarding drag racing. I took my 2008 E91 335i out last night to WillowBank in QLD and made two passes: 12.596 @ 112.65 12.718 @ 111.25 I understand that the times are probably bad due to my poor launches (both times I intended to launch from M2 instead of S1 but failed to remember my launch procedure). But the MPH seams very low to me for an FBO E50 Car, I've included as much information as I possible can think of below in the hopes I could be given some ideas of where to look to increase this MPH with mods or technique, so I can eventually try and eek out an 11.999. My Mods are: Soft: JB4 on Map 7 W/E85 BEF Flash through MHD XHP Stage 3 Hard: Intake Side: DCI, BMS CP, HPF FMIC Exhaust Side: Kittyless DP's + Bashed Mid-Kitty's + Muffler Mod Fuel: 255 Intank pump Setup: Fuel: Around a half tank of E50 (18L of E85 + 12L of 98 on a '---' tank) Tyre: Federal RS-RR 255/40R17's@ 34psi in rear + Federal RS-RR 235/45R17's@ 34psi in front Weight: Unmodified Car W/140KG Driver probably 1800KG Race Weight Launch: Burnout, then launched in S off the foot break Air: I believe it was 28°C @ 60% Humidity last night In-car Video of second run @ 12.7 JB4 Log of second run: https://datazap.me/u/jebusv20/log-15...1-3-4-11-18-24 Time Slips of both runs: View post on imgur.com |
02-09-2018, 10:45 PM | #2 |
204
Rep 1,103
Yeah thats a low trap, on e40 at willowbank i trap 119 my only performance mods are dps and an fmic, fuel it stage 2 pump.
Get onto the Australian 335i group on Facebook too dude. |
02-10-2018, 06:52 AM | #3 |
Rep 7
Can I get some more information about what you were running regarding how you tuned the car, or what boost levels you were at? If you had a log that'd be great, I still have no idea if my logs look clean or not.
