BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > xDrive Clutch Smell
      02-06-2018, 11:56 AM   #1
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
xDrive Clutch Smell
When driving in the snow I get a smell of clutch after a few slides. I know it’s not my transmission’s clutch since I’m pretty much always in 2nd gear when sliding and obviously know how to drive manual properly. Is this a sign the xDrive clutch is wearing out? The xcase fluid was replaced 24k ago.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      02-06-2018, 05:16 PM   #2
ewicky
204
Drives: '07 335xi 4D AT
That's very unlikely as the clutch will be slipping very little if at all in the snow. Instead, you should be looking at your brakes, which are probably getting hot because of DTC/DSC/ediff. E-diff is active even after doing a 3-second press, and it'll be very active if you're intentionally breaking traction.
      02-07-2018, 11:15 AM   #3
Antetokounmpo
1552
That may be it. The t/c was completely off in these cases. I'll smell my brakes next time.
Edit: Was thinking why that hasn't happened the last 5 winters but I did go from stock pads to hawk hps pads last spring so it's a possibility they smell more than stock.
      02-07-2018, 01:02 PM   #4
nsjames
2440
Drives: 08 328xi Touring
the transfercase isn't really vented well enough that you're going to ever smell what's going on in side it.
