02-06-2018, 08:07 AM | #1 |
682
Rep 1,123
DCT Oil Change coming
Will be putting a DCT oil change video out real soon....here's a preview
02-14-2018, 01:28 PM | #2 |
682
Rep 1,123
The promised video to DIY DCT fluid change. EDIT!!! Make sure to use ISTA+ and use the "Service Function". A German Forum member said it would make a difference...I didn't believe it. I re-checked my fluid level again using ISTA+, and there actually was a 400ml difference. I know that's not much, but still better to be safe.
I've added the ISTA+ bit into the video...it's just an overview of using the program when performing the fluid fill. Last edited by Fast400; 02-24-2018 at 10:48 AM.. |
02-14-2018, 03:22 PM | #3 |
711
Rep 1,107
Great video as usual! Thanks again for making these videos and sharing!!
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
02-15-2018, 04:25 AM | #6 |
682
Rep 1,123
If the transmission is a new exchange, then yes. If you are simply draining, filling, and changing filters, you'll get approximately 6.5 Liters out.
I think doing it twice would be a waste of money, for normally used M5 |
02-17-2018, 10:42 PM | #7 |
30
Rep 109
You are the man!!
2014 F10 M5 CP | Black Sapphire Metallic | Sakhire Orange Interior | 343M Wheels | Afe CF Air Scoop | Charcoal Filter Delete | AutoTecknic CF Steering Wheel Trim
02-19-2018, 05:24 AM | #8 |
682
Rep 1,123
Folks! I just learned a bit extra.
A German M Forum member said I should have used ISTA+ to measure temperature and perform the "Service Function". He said it may make a fluid level difference. So I figured what the heck, I'll re-check using ISTA+. I expected no change in fluid level. I wound up adding about 400mL on top of the 6.5L I added previously. I couldn't believe it! I don't think it would be super detremental, but if we're going to do it, we want to do it right....so I'm going to edit the video to show the ISTA+ portion too. |
02-19-2018, 06:25 AM | #9 | |
17
Rep 39
Hmm, thanks for adding that, it looks like I'm going to have to factor in purchasing ISTA+ now, this is not going to be cheap but still cheaper than the dealers and ISTA+ can be used for other things I suppose. So 7 litres of oil now. |
02-19-2018, 06:39 AM | #10 |
4065
Rep 5,231
Very helpful; thanks!
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
02-20-2018, 12:49 PM | #12 |
682
Rep 1,123
03-05-2018, 03:24 PM | #13 | |
111
Rep 433
How much was the mojo power pan? I can't seem to find where to purchase it online. Did you go through HTD performance? |
03-06-2018, 09:30 AM | #14 | |
682
Rep 1,123
Around $1000 |
03-06-2018, 11:08 PM | #15 | |
111
Rep 433
Did you end up using the filters that come with the mojopower kit? Or did you go OEM? |
03-14-2018, 09:16 AM | #16 |
682
Rep 1,123
03-23-2018, 11:10 AM | #17 |
24
Rep 222
Hi. Did you use in first time measuring the oil temperature bimmerlink app? And German language some getribetemperature?? Have test to drive and look this temperature??? Never goes over 55-57 celsius. This is not show transmission oiltemperature. It shows one sensor which is top the transmission.
04-01-2018, 08:02 AM | #18 | |
23
Rep 110
Thanks, Lance |
04-23-2018, 01:23 PM | #19 |
24
Rep 222
Up up?? |
05-04-2018, 02:22 AM | #20 | |
682
Rep 1,123
05-10-2018, 01:40 PM | #21 | |
24
Rep 222
Not. This is not show TRANSMISSIONOIL temperature!!!! (bimmmerlink) How much this bimmerlink show when you are driven maybe 30-45min city driveing or highway? |
05-30-2018, 12:51 PM | #22 |
682
Rep 1,123
Sorry for the late reply. With Bimmerlink temp is 54 C after 20 minutes of autobahn then stop n go for 10 minutes.
