M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      01-31-2018, 06:50 AM   #1
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
Differential Oil change video
All,
I created a quick down n dirty on changing the diff oil. Enjoy!
Appreciate 4
AWF10M5222.50
///3dkn1488.50
His437.50
      02-01-2018, 09:30 AM   #2
Guy M5
Scotland
17
Drives: M5 F10 2014 MCB
Excellent stuff, thank you!
Looking forward to the DCT transmission fluid change video.
      02-03-2018, 08:56 PM   #3
AWF10M5
223
Drives: f10 m5
Nice!
      02-18-2018, 12:22 AM   #4
///3dkn
///3dkn's Avatar
No_Country
1489
Drives: F87 M2C
2019 BMW M2C  [8.67]
Love your videos, very informative. Keep them coming!!
      02-19-2018, 06:38 AM   #5
josec70
josec70's Avatar
4065
Drives: 22' Individual Chalk M5C
Awesome
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      02-24-2018, 07:08 AM   #6
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
Thanks for the video. Two quick tips which may help. 1. Always remove the fill plug first just in case you can not get it out your not left with an empty diff and can not fill it. 2. A cheap hand pump would make easy work of that fill, I bought one years ago to do my diffs, it's worth its weight in gold.
Very helpful video as usual!!
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
      02-24-2018, 12:50 PM   #7
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
Very good point! I was getting really creative trying to route and squeeze the bottle. Sad thing is that I have a Suction/Dispense pump...just didn't think to use it.
Both nuts are on the diff super tight, so removing the top first is definately super important.
I can only imagine removing the drain plug, then not being able to get the fill plug out
      02-27-2018, 11:47 PM   #8
Jasoneo5
39
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
Thanks so much for the video! Curious to get your feedback....have been told by a couple mechanics that it's unsafe to change the trans fluid after 40-50k if it hasn't been done before because the viscosity changed and the solenoids won't like new fluid.
My car has approx 60k now - in your opinion do you think I'd be at risk of damaging something if I did the fluid/filter change? any tips?
      02-28-2018, 11:45 AM   #9
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
I would definately change the fluid...your 'mechanics' are basically hittin you with the old "If it aint broke, don't fix it". With the DCT it only makes sense to change at your mileage. If you do everything correctly and refill with the proper amount and correct approved fluid, you'll be just fine.
On mine I've noticed the shifts actually feel a bit better...might be placebo, but I feel that way.
And changing the diff fluid as described in this thread is a BMW maintanence item every third oil change....no filters though...
      03-23-2018, 07:45 PM   #10
finlandm5f10
24
Drives: BMW M5 F10&Audi RS6 C7 2016
Why ista oil recomend is not redline 75w140 limitedslip oil. This is the. Best oil in the market.
      03-30-2018, 01:21 AM   #11
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
I'm sure the Redline will work just fine. Sometimes it's all about the licensing and money, so it isn't 'approved'.
      08-08-2018, 04:28 AM   #12
theinfamousdrew
I'm The Captain Now
theinfamousdrew's Avatar
501
Drives: X5M/X7
Awesome DIY!
Do you just fill it up till it dribbles out?
Turn on. Tune in. Drop out.
IG: @InfamousCarGuy
      08-10-2018, 12:28 AM   #13
WickedBMW
WickedBMW's Avatar
613
Drives: 2021 BMW M3 MT
What would you recommend for diff oil?
?When you have fast cars and bad luck, it's a lot easier to handle than having slow cars and bad luck.?
Kevin Harvick
      10-28-2018, 09:15 PM   #14
mrtt
38
Drives: E46/E60/E92/F10/E55
did you fill it until fluid starts to drip out of the filler hole?
      11-27-2018, 08:45 PM   #15
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
That's the best way. Do make sure the car is level.
      04-22-2019, 10:57 AM   #16
arsecossie
Drives: BMW M5 F10
Awesome video, thank you! 😊
      04-25-2019, 04:35 PM   #17
AirBull
AirBull's Avatar
78
Drives: 2015 BMW M5
2015 BMW M5  [0.00]
Great video! I enjoy all of them and give you a lot of credit for taking the time to share with the rest of us.
As far as what the best gear oil is for our HAG 220 Electrically Activated M Lock rear axle final drive, (basically an electronic limited slip differential, or ELSD,) these are the four best fluids that I have found that can be had relatively easily here in the US, at least.
I believe the fluid provided in BMW p/n 83222357992 is the same Castrol fluid below, but am not certain. Bottom line is, this one isn't that hard - just pick any one of the following four and rest easy; you only need 1 to 1.5L at most to drain and refill.
Castrol Syntrax Limited Slip 75w-140 GL 5
  • Factory fill, formal BMW approval, (as well as Nissan GTR)
  • Full Synthetic
  • Made in Germany
  • Can be expensive in 500 mL bottles but I found it on Amazon in 1L bottle for $29 shipped
Ravenol Getriebeoel SLS SAE 75W-140 GL 5 LS
  • Polyalphaolefin (PAO) based full synthetic
  • Particularly suited for applications requiring "limited slip" (LS) properties
  • Made in Germany
  • Can be had at Blauparts.com out of Wisconsin for about $24 for 1L
Red Line 75w-140 GL-5
  • Full synthetic formula created from polyol ester base stock
  • Made in California
  • Easily had for about $18-$22 per 1 quart, (ECS Tuning, Jegs, Summit, Bimmerworld, Amazon)
Motul Gear Competition 75w-140
  • 100% Synthetic from Ester base stock
  • Made in France
  • ECS Tuning for about $32 / 1 L
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing
      07-11-2021, 07:12 PM   #18
celicatoe46m3
47
Drives: E60 M5 & E46 M3
I'm also starting to need to do fluid changes. What size is "big ass torx" exactly? =)
m5post
