Spring snapped
01-26-2018, 08:51 AM | #1 |
Rep 12
Spring snapped
So, my front drivers side coil spring snapped last night, luckily within 20 seconds of starting it and only 10 yards off the driveway. The sound it made was ridiculous!
The passenger side front shock has had it (according to a local garage who wouldn't do an alignment because the front left wheel was moving around so much). I was going to replace both front shocks, both springs and the top mounts while i'm there. If I'm going to take the suspension apart I may as well do as much as I can while its apart. Is there anything else I should consider replacing? Also, I was going to replace with SACHS shocks and springs, as they appear to be the brand currently on the vehicle. BMW just quoted me £250 for two springs which seems extremely high to me, anyone got any recommendations? I'm struggling to find the correct springs for the vehicle. Basically I've hit three potholes since the beginning of January and the front of the car feels wobbly and generally rather unstable and the steering wheel is off centre. Thoughts appreciated. Last edited by Chri5J4; 01-26-2018 at 09:13 AM.. Reason: further info |
01-26-2018, 10:25 AM | #2 |
743
Rep 1,096
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
Most BMW experts will recommend you use BMW springs. In fact, I just read a short story on that in the BMW CCA magazine here in the states.
I have been using Bilstein B4s and B6s on my BMWs, and they are excellent alternatives to stock BMW shocks. |
01-26-2018, 10:55 AM | #3 |
New Lifetime Replacement Policy
816
Rep 11,738
You're at a crossroads, time to decide to replace with stock type stuff or go down the performance modification path.
If stock stuff, I highly suggest Genuine BMW or Suplex (stock replacement) springs. For shocks, Sacs is typically the original shock you'll find, Bilstein B4s are also a perfect stock type replacement. Performance modification path.... that can get 'fun'. Everything from springs and shocks (I suggest H&R or Swift springs paired with Bilstein B8 shocks, to coilovers (depending on what you want out of the car TONs of choices), to adjustable air ride suspension. -James |
01-26-2018, 11:16 AM | #4 |
Rep 12
Thanks for the recommendations, I'll give it some thought.
I wouldn't mind resolving the 'bob' at the rear under acceleration. I believe this is typical of a stock 335i . . . |
01-31-2018, 11:58 PM | #5 |
158
Rep 308
Personally i thought the original ride and handling set up on my 06 330d SE was absolute rubbish. Almost sold it after 1st year. Replacing the run flats with standard tyres helped a little but the biggest improvement was swapping out the oe sachs with koni fsd 5yrs ago. Rear spring snapped last year and replaced all with eibach pro kit. Its 90% there now and is main reason ive kept it so long whereas stock was 30%
