TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Adding a sub
      01-21-2018, 02:54 PM   #1
gaz_ball
Drives: E91 335d
Adding a sub
Evening all. I have an E91 with HiFi (676) system that I've upgraded with a JL XD600/6v2 running fronts, rears & underseats (using a Technic harness).
I'm thinking of adding a sub in the boot - is it possible to run the sub off the same amp?
      01-24-2018, 11:05 PM   #2
texasjohn
texasjohn's Avatar
42
Drives: BMW
Your best bet is to drop TechnicPNP an email.
But I don't see why you couldn't tap woofer signals on the harness and then into a LOC.
You'll probably need a second amp?
F10 M5 CP.
Previous: F31 340i, E90 335i SE, E87 130i, F10 550i, E92 335i, E61 550i, E90 335iM, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM)
      01-25-2018, 04:09 AM   #3
gaz_ball
Drives: E91 335d
Thanks for replying.
Had chance to have a bit more of a look in to it & contacted TechnicPNP as well. He said to just take a feed from either the front or rear signals coming from the headunit (same signal).
I will need another amp although originally I was hoping to somehow just use the existing XD600/6v2 - only way to do this I think would be to disconnect the underseats so I've got hold of a XD300/1v2 to power the sub.
The only problem I now have is where to put the sub! I wanted to put it under the floor but then realised last night that I have the shallow underfloor trim (I assume) because of the twin exhausts on the 335. Looking at side mount behind the right wheel arch or possibly a very shallow mount sub (eg JL 13TW5v2-4).
      01-25-2018, 06:53 AM   #4
texasjohn
texasjohn's Avatar
42
Drives: BMW
You want a custom side enclosure... visual ice on FB
Search my recent posts and you'll find some pics, think I put them in the 'what has your 335i cost you this month' thread
F10 M5 CP.
      01-25-2018, 07:16 AM   #5
gaz_ball
Drives: E91 335d
I'm glad you mentioned Visual Ice - found him on FB & saw he'd already done some E90/1 stuff. He's going to take a look at the side mount but also under the floor with a slim mount sub, although I don't think the volume is there even if the sub will physically fit.
I'll have a look at your pics, cheers...
      01-25-2018, 10:11 AM   #6
scottym
Drives: 2011 E92 335i
2011 BMW 335i  [10.00]
I have been speaking with Visual Ice too, regarding a Sub enclosure, hopefully ordering next week.
I ordered one of the generic ones from Ebay and it didn't fit properly and was the wrong colour, it got sent back quite quickly!
My setup is base audio, so I have a little coding to do first.
Planning on a full audio haul myself
      01-25-2018, 03:02 PM   #7
gaz_ball
Drives: E91 335d
That eBay one looks terrible!
I don't envy you having to deal with base audio, so glad mine came with HiFi!
I've done all mine myself so far. I can highly recommend the MB Quart 200.3 direct fit kit coupled with a JL XD600/6v2; sounds leagues ahead of what was in mine as standard.
      01-26-2018, 01:40 PM   #8
texasjohn
texasjohn's Avatar
42
Drives: BMW
Guys
I may have a visual ice enclosure for sale soon. It has a 12" JL Audio 300W speaker already installed with a proper JL grille. I also have a perfectly matching 300W RMS Kenwood amp.
Thing is, I've not actually determined if I'm selling it yet or not, but I thought I'd give you a heads up. If I sell my E90 soon it's all up for grabs. But I thought I'd mention it before you invest in all-new kit. Depends how much of a hurry you are in to get your subs installed!!
As well as that, I have the Technic PNP harness and LOC for the HK system (which probably isn't of any interest to you if you haven't got HK speakers).
F10 M5 CP.
      02-02-2018, 03:50 PM   #9
Zaphod79
Drives: E90 325i msport
I recently got an e90 325i with logic7 and am thinking of adding a sub. I already have a jl audio mono amp and 12" in a sealed enclosure but probably want one of the visual ice corner enclosures and will need the technic harness with loc. Did you sell yours @texasjohn or still thinking about selling the car?
