BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding Experts: What is the easiest way?
      01-21-2018, 09:36 AM   #1
PurpleSector
2018 530i
25
Drives: G30
Dear all G30 coding experts..
What is the easiest way to code?
I heard we can use app (bimmercode) to code simple stuff, and also have an option to use wires with adapters, but you would need to really learn how to code via computer software..
Expertise in the field will be very much appreciated.
Thanks everyone.
      01-21-2018, 02:58 PM   #2
Canuck99
113
Drives: '18 M550i, '15 Jaguar F-Type R
The easiest way is to contact Almaretto and have him do it. The next easiest is to start reading... http://www.bimmerfest.com/forums/forumdisplay.php?f=175
Almaretto2372.50
      01-21-2018, 03:04 PM   #3
csm7djs
67
Drives: G05 X5 3.0d M-Sport
Never used bimmercode but i've heard its just plug and play. So I guess this is without doubt the easiest way to code.
The other method is using a cable and e-sys software. This really isn't for the faint hearted and you need to remember that you can make serious mistakes with this. There are plenty of guides out there to get you started.
http://www.bimmerfest.com/forums/sho...d.php?t=983245
http://www.bimmerfest.com/forums/sho...3#post10193333
It takes a while to download all of the software and ensure you have the correct PSDZData for your car. And then you need to check and double check then even triple check before writing anything to your car. I've learnt this the hard way. And be prepared that without ensuring you know what you are doing, you can quite easily brick modules in your car. There is nothing quite like that feeling when you make a mayor mistake and you get a picture of a car on a ramp when you start the engine.
Anyway lots of scary stories and i've never coded a G30 but done all of my other BMW's. Once the setup is done, you are good to code. I'll probably get all of the files I need for my car I'm just not totally sure if there is really anything I want to code this time around. Might try coding the Enhanced blue tooth to get the office integration.
      01-22-2018, 12:48 AM   #4
Almaretto
Almaretto's Avatar
2373
Drives: Test Vehicles
Bimmercode does not support all G-series ECU's, so you are better off using E-sys or having someone code for you.
      01-22-2018, 08:08 AM   #5
SteveinArizona
3086
Drives: BMW 530e
Almaretto
Almaretto2372.50
      06-24-2018, 06:00 PM   #6
sebash
sebash's Avatar
17
Drives: 2021 Bernina Grey 540i M Sport
can you do remote coding? i'm in socal so couldn't come to you.
      06-24-2018, 06:02 PM   #7
Almaretto
Almaretto's Avatar
2373
I am no longer in SoCal, though I do come back to visit family. Yes, I can do remote coding. PM me if interested.
Search this Thread:
Advanced Search
5post
