01-17-2018, 03:42 PM | #1 |
50
Rep 74
My first track day in the M2
Doing my first trackday in the M2 at Bedford Autodrome on Saturday. Any suggestions for tire pressures etc? Will be a cold day max temp 6 Celsius (I realise americans use Fahrenheit hence).
01-17-2018, 09:22 PM | #2 |
609
Rep 1,124
I suggest 36-38* hot in F*. Sorry but you'll need to convert. I also strongly suggest upgrades brake pads. The OEMs are NOT up to the task ?- ask me how I know! I use Pagid RS29s for track days now. Easy on easy off. You'll spend more time jacking up the car and removing the wheels than you will swapping out the pads.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
Maximoosh49.50 |
01-18-2018, 02:11 AM | #3 |
50
Rep 74
Thanks for that. Am going to do it completely stock to see what would be best going forwards (brakes, power etc) as mentioned itll be pretty cold out there and the car isnt run in yet so I wont be pushing things too hard anyway.
01-18-2018, 12:12 PM | #4 | |
609
Rep 1,124
M2 brake issues with OEM pads http://f87.bimmerpost.com/forums/sho....php?t=1419776 Also do a search on M2 OEM brake pads on track. Best wishes!
Maximoosh49.50 |
01-18-2018, 12:29 PM | #5 |
1622
Rep 3,402
If the car isn't broken in and you won't be running it hard you will be a hazard and frustration to the other drivers. I would hold off till the next track day when you can drive it properly and prep it as recommended. I would add to the recommendations above that upgrading the brake fluid is a good idea also.
Maximoosh49.50 |
01-18-2018, 12:45 PM | #6 |
50
Rep 74
I appreciate the sentiment, I will be running up to 5.5k rpm (plenty fast compared to the other stuff that goes on track days this time of year), ill just get out of the way of the other stuff... im not an advanced track day guy, have done a few in my cayman and also in my mini cooper s before that so not overly experienced. Just going more for exploration to see what needs doing. Are the M performance pads any good? Dont really want much squeal.
01-18-2018, 01:49 PM | #7 |
230
Rep 254
From what I've gathered from this forum. The M performance pads are better than stock but not as good as the "typical" pads run (Pagid RS29, PFC08) and more importantly are more expensive than the two I mentioned.
I personally run the PFCs with typ200 and am quite happy with them. I am at an intermediate level fwiw. Both PFC08 and Pagids squeal like crazy off track. I and others switch them in as needed. It is very easy to change out the pads in this car. Have fun at the track! |
rich8566608.50 |
01-18-2018, 02:15 PM | #9 |
859
Rep 1,148
They're not crap - fine for the street. I agree that taking it to the track before it's 'broken in' is a bad idea, but it's your car.
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone) |
rich8566608.50 |
01-18-2018, 02:17 PM | #10 |
50
Rep 74
Car is currently on 680 miles. Got a 170 mile drive and ill probably take a couple of friends out for some trips before the track so should be there or there abouts by the time its on the track. Run in service booked for monday.
01-18-2018, 03:21 PM | #11 |
795
Rep 3,945
Do not track it with the break in oil in the diff.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
01-18-2018, 03:29 PM | #13 |
5860
Rep 6,631
They say they are the same from M3/M4 so I can only assume the M2 doesn't cool the brakes as well?
01-18-2018, 03:58 PM | #14 |
50
Rep 74
01-18-2018, 04:10 PM | #15 |
230
Rep 254
I looked into that earlier and theyre having the same issues. The problem is with the pad, not necessarily the calipers and rotors. The pads themselves are what breaks down, melts, crumbles, smears itself, disintegrates onto the rotor itself which as others have said makes it seem like the rotor has warped
rich8566608.50 |
01-18-2018, 05:35 PM | #16 |
676
Rep 1,012
That’s seems kind of weird for BMW to have pads on a M car that will do that. I thought that the M2 was supposed to be made for the track. You guys are recommending things that I used to hear on the 2 series forum for the M235i.
When I did my HPDE in my M235i ,my instructor said that the MPSS on my car were just ok for the track. I’ve always thought that was funny since all the reviewers and people on forums rav about them. |
01-18-2018, 05:38 PM | #17 | |
5860
Rep 6,631
01-18-2018, 05:44 PM | #18 |
300
Rep 465
Drives: M2CS
Curious. M Performance pads? These are an upgrade from the stock that come on the car?
01-18-2018, 05:47 PM | #19 | |
300
Rep 465
Drives: M2CS
Let me ask you this. What if you don't stand on them hard or go deep? How do you think they will hold up? |
01-18-2018, 06:41 PM | #20 |
609
Rep 1,124
The OEM brakes are not horrendous and they are perfectly fine for street use. The problem is that the OEM pads break down and smear uneven pad deposits on the rotors when the pads and brakes get too hot.
01-18-2018, 06:44 PM | #21 |
609
Rep 1,124
Yes - definitely get the 1200 mile M service done before the track day. You'll want fresh oil in the engine and the rear diff before the track event.
Aronis2267.00 Bavarienne6.00 |
01-18-2018, 06:50 PM | #22 | |
609
Rep 1,124
Now when I first tracked my '17 M2, I got horrible rotor deposits that took way too long to get cleared up. Now on my M2 I ALWAYS swap in track pads every single time for track events. I never ever want to go back to what feels like warped rotors.
M3 Adjuster7904.50 chief1richard381.00 |
