2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Commercial Marketplace - F10/F11 Classifieds NEW Turner Performance Poly Shifter Arm Bushing Upgrade
      01-15-2018, 03:11 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
818
Drives: Independent Tuning Specialists
Turner Polyurethane Shifter Arm Bushing
The Turner Motorsport Performance rear shifter bushing is designed to remove the shifter play caused by an old failed rubber shifter bushing.
Manufacturing the bushing from polyurethane instead of rubber reduces the amount of stretch caused by the moving part through the bushing.
This maintains the direct crisp feel from your shifter assembly.
When you think performance you may not always think about the parts that don't make power or improve your handling so key upgrades get overlooked.
Even when upgrading your transmission the first upgrade is usually the clutch or a short shifter, but what keeps your short shift kit on target?
The bushings that hold the shift arm assembly in place.
The bushings from the factory are designed from rubber to reduce the NVH from the power going through your transmission, this is designed to be appealing to the mass of BMW customers.
As enthusiasts we are often looking for more of a connection, enjoying some slight feedback from your BMW with improved shifting response & reduced slop for crisp accurate shifting especially when it counts.
When your OE shifter arm bushing begins to fail you will notice slop in shifting potentially making it easier to miss gears and often time causes an obvious vibration and movement from the engine rpm's.
If you're looking for noticeably crisper shifting without adding much NVH (Noise, Vibration, & Harshness) then this is the bushing for you.
Features:
Corrosion resistant 304 stainless steel mounting sleeve with bonded 70a polyurethane
Stiffer bushing results in crisper shifter feel and a more engaging driving experience.
Ready to install out of the box - no modifications required
Replaces Genuine BMW part number 25111220707
Improved durability over OEM rubber
Made in America
Click HERE for your E82/E88 1 Series and 1M Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E36 3 Series and M3 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E46 3 Series and M3 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E9X 3 Series and M3 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your F3X 3 series Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your F80/F82/F83 M3/M4 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E39 5 Series and M5 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E60/E61 5 Series and M5 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your F10 5 Series and M5 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E63/E64 6 Series and M6 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your F12/F13 6 Series and M6 Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your E31 8 Series Turner Performance Poly Shifter Arm Bushing Upgrade
Click HERE for your Z3/Z4 Turner Performance Poly Shifter Arm Bushing Upgrade
5post
