Charge pipe and need for BOV
01-13-2018, 05:19 PM | #1 |
55
Rep 107
Is there a certain amount of boost pressure before a blow off valve is needed? Would I be able to get along with one without a blow off valve if I didn’t intend on going to high boost pressure’s?
01-13-2018, 05:43 PM | #2 |
Rep 33
I ran 21+ psi on stock turbos with stock DVs vented to atmosphere with no issues. I'm now VTT Stage 2+ with stock DVs at 19 psi vented to atmosphere. Never once had a leak, and if one fails, you can find a perfectly good used set from almost anyone on the forums for around 30 bucks
01-15-2018, 05:23 PM | #3 | |
BimmerPost Supporting Vendor
24328
Rep 191,065
Worst case scenario, DV leak in the future you keep the same charge pipe and get the upgraded Forge Diverter Valves
TemjinX2520.50 |
01-15-2018, 10:08 PM | #4 |
521
Rep 1,484
