01-12-2018, 09:52 PM | #1 |
NewFinishColumbia/detailer
604
Rep 2,096
Wipers and what have you used?
So I'm starting this thread because for a while, the first year I owned the 228i from 2015-2016, there weren't many aftermarket choices for replacement wipers. Of course there was the OEM offerings but if I'm spending the money anyway I may as well find out what's out there. For reference as far as conditions I have lived in South Carolina since August of 2015 when I retired and moved back here. I bought my car in June of 2015 with 2700ish miles on it. It's a 05/2014 build car and was used as a loaner for someone who ordered new while I was in Germany until their car came in.
OEM: The BMW wipers that came with my car were ineffective after about 9 months of use. I had them replaced at about the same interval through "free maintenance" at the dealer during an oil service. Those made it about 11 months until they wore out and started separating from the hard portion of the wiper itself. Wore out pretty early IMO but I did put a ton of miles on the car in a short amount of time. Always worked flawlessly as intended. Bosch: $47/set @ Wal-Mart I decided to replace the BMW OEM wipers with the Bosch ICON wipers that had just hit the market for the 2 series in the stock 22" (driver side) and 18" (passenger side) sizes. Installation was a bit complicated by the need to remove a bunch of different covers and add clips in order to work properly with the stock wiper arms. For this reason the wiper's had to slip onto the arm itself and the tension that was applied to the glass was lessened. The spring tension of the arm was lessened because the glass/arm angle was lessened. Worked well for about 14 months. They started to chatter on occasion and started to dry out I think. Compounded by the lessened pressure on the glass made it worse. They finally gave up last night. The contact portion of the wiper came detached from the wiper and started flopping around. Of course it was raining pretty hard when this happened all of a sudden. Rain X: $57 @ Target This time around there are many more wipers to choose from and I decided to go with the new Latitude series from RainX. Installation was pretty straight forward as the included instructions are well thought out. You have to remove 2 small cover/bracket items and the end of the wiper arm inserts into the wiper. By design the glass to wiper arm distance is greater than the Bosch wipers and contact with the glass is more pronounced as it is with the stock wipers. It was raining again today during this warm spell that just hit again, it was 69 degrees today. They work great so far and don't make a peep. We will see how long these last. I hit 68,097 miles today and it's time for other maintenance items as well. What have you used?
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
01-13-2018, 12:51 PM | #2 |
Kingslayer
411
Rep 1,479
I've always used OEM and have had zero issues. I think BMW has some of the best wipers of any make. With that said you probably do more miles than me (about 9-10k/yr for me). I also make sure to clean them whenever I wash the car. I use some washer fluid on a micro fiber. This is my 5th BMW and have always been impressed with the wipers.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
01-13-2018, 01:59 PM | #3 |
Car Geek
3621
Rep 3,591
I've also found the BMW wipers to be very good compared with those from other manufacturers.
SteveInfante604.00 delvec0389.50 |
01-21-2018, 10:19 PM | #4 |
14
Rep 34
How much are OEM wipers? I have an Acura and they use the inserts which are pretty cheap to replace.
SteveInfante604.00 |
01-21-2018, 11:45 PM | #5 |
Car Geek
3621
Rep 3,591
About US$47 for OEM or US$23 for Bosch equivalent (part number 61612219147 for the pair), no inserts the blade and rubber are a single item.
01-22-2018, 07:36 AM | #6 |
604
Rep 2,096
Thanks for the input. Keep chiming in.
01-22-2018, 10:22 AM | #7 |
1399
Rep 5,262
You can buy them ONCE here https://www.fcpeuro.com/products/bmw...es-61612219147
and then return them anytime you want for a new one... |
01-22-2018, 10:31 AM | #8 | |
463
Rep 778
01-22-2018, 01:17 PM | #9 | |
25
Rep 72
Bill |
01-23-2018, 08:55 AM | #10 |
604
Rep 2,096
So far so good with the latest RainX ones I got. Quietly cleared all the rain in a heavy storm with ease.
01-23-2018, 08:56 AM | #11 | |
604
Rep 2,096
01-23-2018, 10:41 AM | #12 |
1399
Rep 5,262
01-23-2018, 11:06 AM | #13 |
313
Rep 525
I almost never use my wipers so I only tend to replace them every few years, at the earliest. Rain-X, ceramic coating, and similar products usually does a good enough job for the weather we have in TX. Didn't realize the damn wipers were so much for this car, though.
01-23-2018, 07:02 PM | #14 | |
604
Rep 2,096
I'm all for not wasting my hard earned cash but performance versus price is more important than the hassle to me.
01-26-2018, 10:54 PM | #15 | ||
Kingslayer
411
Rep 1,479
04-06-2018, 01:20 PM | #16 | |
15
Rep 50
I like fcp euro myself. Probably will go with them...or just RainX from Amazon!! Usually replace yearly on all my vehicles in October. biz
2014 BMW 228i f22 n20 Prod.date: 2014-06-27 ^^^^^^^^^^^^^^^ |
09-26-2021, 09:09 AM | #18 | |
444
Rep 1,264
09-26-2021, 12:50 PM | #19 | |
1306
Rep 1,146
I only use OEM/Dealer |
09-26-2021, 02:32 PM | #20 | ||
1399
Rep 5,262
09-26-2021, 10:22 PM | #21 | |
Thaumaturge
181
Rep 211
I probably would use the guarantee for brakes too but they don't stock the brakes and rotors I like. ///Rich |
09-27-2021, 09:49 AM | #22 | ||
1399
Rep 5,262
Then cabin filter, wipers and brake pad sensors on another one |
