Almost finished... leather covered console trim
01-12-2018, 11:55 AM | #1 |
1208
Rep 2,835
After getting a split armrest, I haven't been happy with just a plain plasticized piece of wood covering the center console.
So I picked up a cheap trim piece for the retrofit and covered it in leather. Still have a bit of touch up to do. So far.... |
01-18-2018, 03:05 PM | #3 |
1208
Rep 2,835
01-18-2018, 10:22 PM | #4 |
4276
Rep 9,206
Shave the frame a little where the Idrive controler is to offset the thickness of the leather. Do the same in other tight areas. Also spray glue might work better. Good job over all. When you say CIC trim piece are you thinking of the black plastic cover? I have one I would like to get ric off.
01-19-2018, 07:01 AM | #5 | |
1208
Rep 2,835
Because of the sort of twisted curvature of the trim, especially the left edge, you have to work at it slowly. So I was literally in some spots only putting glue on half an inch at a time to get it to lay down correctly. Sorry, I'm talking about the whole piece when saying CIC trim. I guess the CIC center console trim would be more precise. I can find tons of CCC, but very few CIC. |
01-19-2018, 07:33 AM | #7 | |
4276
Rep 9,206
While back I reupholstered some car seats. I supply the leather and it came with few crease marks from being folded. They used steamer to soften/loosen up the leather. I guess iron that can spray water would to the same? |
01-19-2018, 08:10 AM | #8 | |
1208
Rep 2,835
Yeah... I'm not happy with it the more I look at it. |
01-19-2018, 11:11 AM | #9 |
4276
Rep 9,206
If is showing creases from imperfections on the center console itself you could try thin foam padding.
01-19-2018, 11:29 AM | #10 |
1208
Rep 2,835
02-08-2018, 07:55 AM | #11 |
1073
Rep 1,957
Drives: E90 M3 LCI Jerez Black
That leather needs to be stretched. Heat it woth some steam, get it supple, then you should get some better, smoother results.
