Track suspension recommendations
01-05-2018, 03:26 PM | #1 |
18
Rep 50
I am new to the e92 and would like to ask for some advice on suspension setup for a car that will see a lot of track time but should still be tolerable on the street as an occasional daily driver.
I am open to all suggestions on suspension but I would like to start with selecting a spring/shock combo or coilovers. I'd prefer not to spend more than $1.5k on this part and so am currently looking at options like the ST XTAs. I am fine without adjustable height as long as it sits a little below stock (currently M-Sport package). Generally, if I could spare the hassle and expense of coilovers, I would prefer that but I also don't want a setup that's too soft for the track. I posted this on the suspension forum but didn't get as much feedback from the track crowd as I hoped. Many thanks for the help. |
01-05-2018, 08:58 PM | #2 |
Professional Hack
96
Rep 379
Try to find a set of used KW V2's or V3's depending on how much mileage is on them. Used V2's will give you adjustable ride height and adjustable rebound.
The M3 front control arms will give you more negative camber in front, in which the stock e82/e90's are sorely lacking. Also consider upgrading your rear subframe bushings to the more robust M3 versions. Have you thought about changing out your tires to a track-oriented yet still road-worthy tire? (Are you still on run flats?) |
01-05-2018, 09:22 PM | #3 |
711
Rep 3,251
avoid KW. IMHO they are a go to options only because all the marketing they do and people don't know better. they are overpriced and the valving is all wrong. for the money, there are much better options.
if you dont need height adjustable features, I would recommend just getting a set of Bilstein HD or BMW Performance shock paired with BMW performance springs.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
Taskmaster2465.00 |
01-05-2018, 11:58 PM | #4 |
18
Rep 50
Thanks for the replies. I feel I am in the right place.
The runflats are gone and I'm on potenza re71r's, which are possibly the best tires I've ever had. M3 control arms and solid subframe bushings are in the plans, as well as an LSD once the budget allows. Are there others who feel that KWs/STs are overhyped? I would certainly be glad to go with a shock/spring combo like Cloud9blue suggested if it saves me a buck and allows for track-worthy handling. |
01-06-2018, 07:49 AM | #5 |
Professional Hack
96
Rep 379
Everyone has differing experiences with and opinions on brands so I'll leave it up to you to decide; I feel KW, Bilstein, Ohlins, TC Kline and Ground Control are good options to look into.
But getting a set of non-adjustable shocks left me quickly wishing I had spent the extra money or waited for a decent used set with height/rebound adjustment. |
Unknown_Car447.00 |
01-07-2018, 01:42 PM | #6 | |
711
Rep 3,251
I also had BMW PS for over a year. They were great for the money IMO. They just rid a bit harsh (too much high speed damping???) in first 100 miles or so for whatever reason. I would recommend against the Ohlins Road and Track kit (not the real Ohlins kits with TTX shocks) for our cars. Their spring rates are all wrong for these cars. Plus their shock rusts if you DD them... Get a kit with stainless steel shock body instead if you gonna drop the money on a nice set of coilovers. You don't want you spring collar seized against the shock body.
Taskmaster2465.00 Unknown_Car447.00 |
01-07-2018, 04:46 PM | #7 |
Professional Hack
96
Rep 379
Interesting, yeah I've heard really good things about MCS and JRZ, most people love TC Kline. The main reason people have reservations about the Ohlins is from what I've heard, they are a fat strut and cause wide tire clearance issues.
I went with KW because I found a good deal on a used set of V3's, but I have no real allegiance to any manufacturer. |
Unknown_Car447.00 |
01-08-2018, 03:35 PM | #8 |
18
Rep 50
The inputs have been great and I am continuing the research. I may be able to get a good deal on some single adjustable TC Klines, which were initially a bit more than I wanted to spend.
What spring rates would be recommended for a track/street setup? I'm currently thinking 400#/700#. Thank you. Last edited by SF335; 01-08-2018 at 05:13 PM.. |
01-08-2018, 05:31 PM | #9 |
4276
Rep 9,209
I'm on BMW PS springs with Koni yellow adjustable. I would suggest you to spend the money else where. Like cooling, brakes....Maintenace is also big factor. Vehicle must be capable of sustaining track abuse. Suspension will not offer you much. Very little actually unless you are pro race car driver.
01-08-2018, 08:57 PM | #11 |
4276
Rep 9,209
Here is info on spring rates: http://www.e90post.com/forums/showthread.php?t=235797 They pair well with Koni. I also have CG camber plates. They help the most, with tires of course.
01-09-2018, 12:46 PM | #12 |
18
Rep 50
It looks like these are about 200#/500#, which is just a little stiffer than stock on the e92. Does anyone know if these shocks would work well with a stiffer spring?
Also, does anyone know of any springs out there that give a slightly bigger drop for the M-Sport and have rates closer to 350#/600# |
01-22-2018, 01:04 PM | #13 | |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
Start with the stuff that matters the most: tires, brakes, brake cooling, alignment. Then run a few events and then get comfortable with the car. Then go to the next phase.
tetsuo1111227.00 |
01-25-2018, 05:38 PM | #14 | |
Boost
1354
Rep 3,693
Drives: 135i M-Sport
Or used Ohlins?
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
01-26-2018, 03:40 PM | #15 | |
711
Rep 3,251
I would just stick with Bilstein PSS10.
01-26-2018, 03:48 PM | #16 | |
Boost
1354
Rep 3,693
I may be bailing on the 135 racecar (later in 2018) and building an E46 M3. Anyone have experience with the higher end Fortune Auto coilovers?
01-26-2018, 04:31 PM | #17 | |
711
Rep 3,251
01-26-2018, 04:48 PM | #18 | ||
Boost
1354
Rep 3,693
The TTXs look frickin amazing, don't think my ability levels quite match up though haha
feuer4275.50 Unknown_Car447.00 |
03-07-2018, 06:32 PM | #19 |
48
Rep 310
Why is everyone hating on the Ohlins Road and Track. I had them for two years on my E46 M3 and they where amazing and I just ordered a set for my E92. I do agree that the spring rates from the factory are less than ideal, especially for and kind of track use but once upgraded with Swift springs I would venture to say they are some of the best if not the best Coilovers at there price point.
As far as rusting goes, I live in Rhode Island where they go absolutely nuts with salt in the winter and I DD'd my car every winter and never had any problems. I would highly recommend Ohlins R&T's with Swift springs if you're looking for a set of Coilovers. |
03-08-2018, 09:33 AM | #20 | |
711
Rep 3,251
03-08-2018, 09:43 AM | #21 | ||
48
Rep 310
MCS Singles are over $3000 when you include springs and the other stuff needed to actually install them. Not to mention the would not hold up to DD duty as they are made of aluminum and will rust The AST 5100's are not on the same level as the Ohlins and the 5200's are far more expensive JRZ RS Sports are over $3000 when you throw in the springs and height adjusters and are again made of aluminum TC Kline Singles are not on the same level as the Ohlins. The Doubles are but they are also a lot more expensive The Only Dampers KW makes that can compete with the Ohlins are the V3 and in track they are equals for sure but on the street the 2-way V3's are not as good as the Ohlins, you would have to step up to the 3-ways which not only more expensive than the Ohlins but are also far more complex |
03-10-2018, 02:08 AM | #22 | |
2465
Rep 9,004
