2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Car won't keep time...CEL is on
      01-04-2018, 08:09 PM   #1
Draab2006
Drives: M235i
I posted this in the tuning section, but didn't have much luck getting any responses. Hoping someone might have an idea where to begin!
My 2015 M235i won't keep time...in that the time displayed in both the instrument cluster and nav screen never changes. You can set it, but it'll never advance, either in automatic mode or manual mode. Additionally, the car has thrown the codes of P15FD and P15FB, which both relate to "Engine switch-off time: Too slow during engine operation" and "Engine switch-off time: Too slow during after-run"
Would it be safe to assume that because the clock isn't 'ticking', that it's thinking the engine is 'dieseling' after shut-off, thus tripping a code?
My rationale in thinking this is that further reading about these codes indicates "The diagnostic function compares the internal timers of the DME and the instrument cluster when the ignition is switched on again while the control module is in its shutdown phase"
Could...could a simple battery disconnect kick start this damn clock??
2017 ///M2 Long Beach Blue M6
      01-04-2018, 08:16 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
604
Drives: 2015 F31 xDrive
That's the first thing that I thought of after reading your post. I would try that and leave it disconnected for at least 20 minutes before hooking it back up. After you get it back together then try and set everything again, drive it, and then see if the codes come back.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      01-04-2018, 08:25 PM   #3
Draab2006
Drives: M235i
Glad to see I'm not the only one who thought that...I will do that and report back. My web searches hadn't yielded many results about these codes in particular, so if I can solve this hopefully it'll help someone else in the future. Thanks!
      01-06-2018, 12:03 PM   #4
Draab2006
Drives: M235i
Yep...disconnecting the battery for 20 minutes fixed the issue. What a strange anomaly; glad it was simple! Hope this helps someone else in the future.
Appreciate 2
aozer994.50
BM235iW97.00
      01-06-2018, 03:06 PM   #5
SteveInfante
604
I'm glad that worked for you. Now we know....
      01-06-2018, 08:14 PM   #6
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
That's a happy ending. Glad it worked out for you OP.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      12-21-2019, 02:08 PM   #7
Dimundz
Drives: 18 X3 M40i & 14 328i xdrive
Hello Draab2006
I have the same code P15FB on my '14 328i xdrive - External Engine Off Timer Incrementation Too Slow During Engine Running
My clock is also frozen.
My car was coded in 2015. Has yours been coded?
I am going to try and disconnect the battery for 20 min and see what happens.
      12-21-2019, 09:20 PM   #8
Dimundz
Disconnecting battery for 20 minutes seems to have fixed the problem.
CEL did not come back on after driving for 1 hour.
Clock is keeping time again. Fingers crossed car doesn't blow up.
BM235iW97.00
      12-22-2019, 08:42 PM   #9
BetweenTheWheels
BetweenTheWheels's Avatar
81
Drives: 228i M Sport
Just stumbled on this and what a big help! I had my car running on battery during testing of new retrofitted lights and afterward it has not kept time - every after two resets. I'll have to try the tactic of disconnecting the battery to see if that solves my issue.
Thanks for posting!
Current: 228i M Sport
Former: E85 Z4 3.0, E89 Z4 35is, 28 others....
      12-22-2019, 10:27 PM   #10
AndDown
Just Copacetic!
177
Drives: 2019 F22 230i MSport
Our cars are computers on wheels - similar to re-booting a computer solves the problem! Good to know, thanks!
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
2addicts
