01-02-2018, 07:36 PM | #2 |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
Seems like the cluster is rebooting. I would think faulty cluster or a short circuit.
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
01-03-2018, 12:00 AM | #5 |
1403
Rep 5,262
01-03-2018, 12:28 AM | #6 |
35
Rep 37
01-03-2018, 12:51 AM | #7 |
25
Rep 97
I was the OP in the above linked thread. I was seeing the issue only under the condition of being at a specific intersection and navigation active with a route. It was fixed after a software update. I will see if I can find the work order for this
01-03-2018, 08:16 AM | #8 |
445
Rep 1,264
There’s a software update for the gauge cluster. The dealer will install the update for free. It takes about 2.5 hours for the software to load. What are they using, an RS32 cable?
01-27-2018, 04:24 PM | #9 |
32
Rep 245
Thanks for the replies, i checked the other threads and they seem to line up. Nav was on, some part of orlando, can replicate it any time i drive there. Nothing urgent i suppose so im waiting till my next service appt.
02-01-2018, 11:56 AM | #10 | |
35
Rep 37
Simple temporary fix ... I was also having issues with my 2016 M235i and found a temporary fix or permanent if you don't care about showing the turn by turn on instrument cluster. As many others have already pointed out, the problem is related to the navigation displaying the turn-by-turn directions on the instrument cluster and here is a simple fix until you have time to goto the dealer to update the navi code. Goto Main Menu -> Settings -> Instrument Cluster Uncheck Navigation |
