12-30-2017, 12:22 AM | #1 |
64
Rep 310
MPE with aftermarket tips. - anyone running them?
wanted to change my MPE chrome tips to something bigger and maybe with a CF accent..
lots of Akraprovic style tips, as well as MPE CF style tips on ebay... has anyone already done this and if so, would you mind sharing your setup with pics and info? what is the outlet size on the MPE muffler w/o tips.. im measuring around 60mm without the tips...
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
12-30-2017, 01:20 AM | #2 | |
46
Rep 160
12-31-2017, 01:12 PM | #4 |
No 55mph
1622
Rep 8,476
BMW made sure to expand the ends of the tailpipe to 3-5/8 at the ends where the tips attach to pretty much stop anyone from using aftermarket tips, as that size is not normal...
I searched for quite some time for aftermarket tips before buying my MPE, never found anything that would work, even with clamp on style - either too small or too large Ended up buying the OEM CF tips Now the stock exhaust ends are more conducive to many aftermarket tips
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-31-2017, 04:38 PM | #5 | |
Rep 34
12-31-2017, 04:52 PM | #6 |
No 55mph
1622
Rep 8,476
Yes, cutting and custom welding is definitely an option
I just decided to take the easier albeit more expensive route
04-22-2018, 01:42 PM | #7 |
89
Rep 287
Drives: 2014 335i 6MT MSport
I can't even find the CF tips used anywhere. When I had the MPE installed they took the OEM chrome tips off the stock muffler and banged them on to the new one, but they're cheap-looking. HOWever I don't want to spend $450+ for new CF tips or even $200+ for the M chrome tips. This is stupid.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
04-22-2018, 06:13 PM | #8 |
597
Rep 1,805
Check eBay
Lots of rep tips Any muffler shop can make it work
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
04-25-2018, 09:16 AM | #10 |
611
Rep 434
I've spent countless amount of days looking into this as well. I've tried even buying tips from a member here who said he makes them work for the MPE and it didn't fit. I've checked all over eBay as well for custom tips that would just slip on and still no luck. I really don't want to have them welded on as I enjoy to take them off to clean them from time to time. Would love to see if anyone finds a solution to this.
2014 335i 6MT /// Mineral Gray - Red Coral
| M Perf Spoiler | M Perf Lip & Diffuser | M Perf Grilles | M Perf Side Splitters | M Perf CF & Alcantra Interior Trim | | Wagner Evo II FMIC | VRSF DP | AA CP | CTS Turbo Intake | MHD Stage 2 Tune | H&R Sports | Bilstein B8s | |
04-25-2018, 11:07 AM | #11 |
5559
Rep 5,374
I'm running the 3.5" black chrome BMS tips with the MPE on my M235. No modification is needed to get them to slip fit. It's the same exact MPE muffler and piping design as the one used on the F3X series. I originally had the MPE chrome tips, but they were a bit too small in diameter for my liking.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-25-2018, 12:21 PM | #12 | |
611
Rep 434
04-25-2018, 12:37 PM | #13 | ||
611
Rep 434
Update:
Just did some quick research on the forums and apparently OP has recently tried to install the BMS tips on their MPE and they said it fit. Quote:
04-26-2018, 08:30 AM | #14 | |
5559
Rep 5,374
04-26-2018, 01:13 PM | #15 | |
611
Rep 434
06-02-2018, 07:00 AM | #16 | |
395
Rep 1,010
Thank you all for the helpful information.
Which BMS tips did fit as they have many tips with different shapes and sizes, also any idea if the BMS 4” outlet tips fits both the MP pipe and the OEM diffuser ? Thanks. Quote:
06-02-2018, 12:00 PM | #17 |
485
Rep 1,105
I'd assume you'd purchase the ones made for your model and year.
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
06-16-2018, 04:00 PM | #18 | |
89
Rep 287
Any idea how to get the old ones off I don't care if they survive the removal. They were the OE chrome tips that came with the stock exhaust so I would think they are on there really tight. The installer removed them from the old muffler and banged them on the new MPE.
06-17-2018, 05:15 AM | #19 |
140
Rep 216
Drives: F30 335i PWG
I have a set of the Akrapovic replica tips, in matte carbon and they look really nice and the carbon fibers' quality is really good much better than expected
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
aps336.50 |
06-17-2018, 11:43 AM | #20 | ||
967
Rep 2,655
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
06-18-2018, 01:56 PM | #21 |
611
Rep 434
Glad to hear that, I already ordered the 3.5" BMS tips but they're currently on back order for 2-4 weeks so I'll be posting a picture for sure once they arrive and I install them.
06-20-2018, 09:25 AM | #22 | |
5559
Rep 5,374
Zara610.50 |
