12-23-2017, 05:04 PM | #1 |
14
Rep 28
Intake Recommendations?
Hey guys, I'm on the market for an intake and am split between purchasing the BMS Billet Intake and the Agency Power short ram intake for my 2017 B58 M240i. I was wondering if anyone has either product and can offer some feedback! To be honest I'm more interested in a really nice sound than anything else. I had the N55 BMS short ram intake on my old M235i and I loved it, but the newer B58 M240's have just the billet cone from BMS whereas Agency Power has a full short ram. I really don't want to buy the BMS intake and it ends up being quiet, but I do prefer all burger products as they are well trusted. Any recommendations/vids/tips? Thanks.
12-25-2017, 12:47 PM | #2 |
445
Rep 1,264
The factory intake has a built in air cooler. So, unless the new intake has the ability to cool the air from the turbo you’ll be loosing power.
12-25-2017, 06:40 PM | #3 |
98
Rep 235
Agency Power is much louder than the BMS but people do have some issues fitting it in the engine bay or have issues with the way it was made. I personally had no issues with it or install and it sounds amazing.
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe |
12-27-2017, 12:44 PM | #4 |
Joint Chiefs of Staff
24191
Rep 190,805
We offer both, Agency Power is louder
12-27-2017, 12:47 PM | #5 | |
24191
Rep 190,805
Here is a test done on the N54 (turbo BMW) with dyno graphs Repost from 2012: So for this round of testing we used our 135i which happens to be 100% stock at the moment aside from the JB4 using 91 octane + NOS octane booster (~93 octane). I've been testing map 2 with a default CPS offset lately so kept that all the same between both tests. The two sets of tests were performed within 20 minutes of each other under identical conditions. First I did a 40-110mph sprint (on a private track) to evaluate the intake temperature increases throughout the run. Secondly an 8 minute (limit of JB4 logs) idle test simply logging the car with the hood down and AC on to monitor intake temperatures at rest. According to "hot air" conspiracy theorists the dual cone intake should result in higher intake temperatures during the wide open throttle run, no power gains, and heat up dramatically sitting at idle soaking up all that engine heat. First up: Stock intake system Next up: BMS Dual Cone Intake Results: I hate to say it again but the results were exactly as expected. The DCI did not produce higher air intake temperatures at wide open throttle, did not heat soak more sitting at a standstill for 8 minutes, and all around felt faster. I should also add it's certainly possible modifying your OEM airbox with an extra filter might offer minimal gains over a dual cone intake assuming you don't mind up cutting up your factory airbox but don't expect much. We've tested this as well with no significant performance gain over a DCI in 40-120mph VBOX times. You have a lot of options for intakes but three+ years later the tried and true DCI is still the intake of choice for those of us who are serious about performance...
12-27-2017, 09:24 PM | #6 |
809
Rep 1,369
Lol, what?
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
12-28-2017, 10:32 AM | #7 | |
445
Rep 1,264
12-28-2017, 10:58 AM | #9 |
24191
Rep 190,805
Its an N54 not N55 and i stated that in the first sentence of my post.
It still applies, unless you have data showing otherwise
12-28-2017, 05:33 PM | #11 | |
24191
Rep 190,805
Some customer want very aggressive sound (Agency Power), others want a mild increase over stock (Burger Tuning). We are happy to offer both. Thank you for your order!!!
