12-21-2017, 01:40 AM | #1 |
179
Rep 565
being lazy....torque setting for 19" wheels
I'm still in bed and got thinking. Im going to fit my 10mm and 12mm spacers today and they are still in the garage..... Is there torque setting supplied for the bolts? Or do just used the same value when not using spacers. If so what torque do people use?
12-21-2017, 02:04 AM | #6 |
49
Rep 131
12-21-2017, 02:42 AM | #7 | |
547
Rep 1,484
I've always used copper grease on the wheel mating surface to ensure that the alloy does not stick to the hub, having once experienced that situation. |
12-21-2017, 02:54 AM | #8 |
325
Rep 709
I’d like an explanation too. I’ve got three decades of doing this and more miles than I’d like to count , both on and off road, with not a single issue. Am I about to die in some horrible accounts accident when the wheels coming flying off my car?
12-21-2017, 03:02 AM | #9 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
12-21-2017, 03:55 AM | #11 |
547
Rep 1,484
12-21-2017, 04:02 AM | #13 |
579
Rep 1,215
Glad I saw this, I was just about to swap my wheels over without any grease at all.
12-21-2017, 04:22 AM | #14 |
547
Rep 1,484
12-21-2017, 04:23 AM | #15 | |
547
Rep 1,484
Thanks, will now adjust accordingly. (Every day's a school day) |
12-21-2017, 05:01 AM | #16 | |
6659
Rep 15,858
Although a wheel fixing appears the simplest of fastener systems, it has quite a complex function to perform, as fasteners go. We have to accommodate radial position and load, axial loads, vibration and the transmission of torque, all with a simple bolt, with no secondary 'backup' locking feature. The spigot supports the radial position and load, (hence the importance of correctly matched spigot and hub dimensions. The bolt deals with the axial loads and supplies the clamping force to the friction face, which subsequently transmits the torque without slip. No way should a wheel bolt support the radial load, (loose spigot), or be transmitting the driving torque, neither functions are intended in a wheel's fastener system. Lubricants change the fastener's dynamics, both in the bolt's applied torque and the coefficient of friction between the wheel and hub. Lubricants can contribute to relaxation of the torqued assembly. Hence why we only apply anti-seize compounds where there is no compromise to the clamping force or bolt torque value, just the spigot area. Lubricant on the bolts... we have to recalculate the torque value, based on the new coefficient values, as a result of the lubricant we are using (lubricant type) and where we put it. For example a 'wet' bolt, where threads and under head face are lubricated, a torque value of 140 Nm for the M14 bolt will mean it is grossly over torqued. |
12-21-2017, 05:13 AM | #17 | |
179
Rep 565
Thanks |
12-21-2017, 06:53 AM | #18 | |
23
Rep 132
Nope, there's no problem using copper slip on the hub faces. It prevents the wheel seizing on the hub. The clamping force provided by the bolts provides enough friction between the mating faces to negate this once the wheel is torqued up. |
12-21-2017, 07:09 AM | #19 | |
6659
Rep 15,858
12-21-2017, 10:25 AM | #20 |
23
Rep 132
Each wheel is held on by a clamping force of around 5 tonnes-force or 50KN, so even if the coefficent of friction is lower due to anti-seize compound its still enough force. Don't forget the bolts and spigot also hold on the wheel via a shear force and the shear strength of each bolt is approx 5 tonnes-force. So its not going anywhere!
12-21-2017, 10:56 AM | #21 |
325
Rep 709
HighlandPete I would love to accept the theory that the bolts hold the wheel on and the torque is transmitted between two smooth surfaces. Why is the rear of the wheel cast to reduce the mating surface and if the surfaces were designed to transmit the torque why are they not keyed to each other to prevent slippage?
Still doesn’t explain why my wheels haven’t fallen off. I’ve searched the internet but can’t find anything on the consequences of using copper slip on the mating surfaces. Also baffled why F1 and exotic cars use Center Lock (one big nut) and locating lugs which reduces the mating surfaces but allows lighter wheel designs and bigger brakes. |
12-21-2017, 08:04 PM | #22 |
566
Rep 1,137
