Carly Do’s and Don’ts?
12-19-2017, 10:42 PM | #1 |
Rep 12
I just got the Carly app and Bluetooth connector for my 2011 335i with premium and sport package. I primarily got the app and connector to register my new battery but I’m also interested in the coding features. My question isn’t necessarily about coding but more about if there are specific best practices or things I need to be aware of when using the Carly App.
For example should the car be off, ignition on, running? Should the battery be connected to a tender? Looking at the coding there’s many options that don’t seem to pertain to my car like CAS features even though i don’t have the comfort package. Will changing these settings do anything positive or negative for my vehicle? Is there any “permanent” changes or damages that can be done with the Carly App or is it all reversible? Essentially is this an app for dummies or something that should be used by a trained professional or with proper research? Thank you for any info or direction you may provide! Last edited by Spectrum24x; 12-19-2017 at 10:50 PM.. |
12-20-2017, 12:06 PM | #2 |
13159
Rep 1,965
Getting one for Cribmus.....subscribed.
I have a friend that just did some coding on his i3. He stated that its better to do one at a time versus trying to code all sorts of shit at once. He stated that you spend more time trying to correct errors than by doing one at a time. |
desertman1232215.50 |
12-20-2017, 03:50 PM | #3 |
27
Rep 96
Drives: 2011 BMW E92 335i V. Red/SB
Some tips using Carly
Make sure you have a good battery as the app needs at least 12.5 v to code I find that running the engine makes diagnostics quicker - it reads the modules quicker but for coding I just have ignition on The app is fairly fool proof - if a coding fails just try it again Good luck |
King Rudi13159.00 |
12-20-2017, 05:11 PM | #4 | ||
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
King Rudi13159.00 |
12-20-2017, 05:35 PM | #5 |
[Oo=||=oO]
1105
Rep 2,470
check coding section - there is big thread on this subject.
When doing anything with the app, just do it with your car running. That way you have less chance of messing up due to battery failing. App backs up everything prior to doing any coding, so you can revert back to the original (as long as you have the backup). |
RoarinForeign35.50 Spectrum24x2.50 |
