Does your AUX sound like absolute hell?
12-14-2017, 12:48 PM | #1 |
264
Rep 459
So I have a 2009 335i coupe with Hi-Fi and nav, and my brother has a 2009 Nissan Rogue with Bose. His stereo sounds great with an Aux cord to his phone, easily CD sound quality. His car got mashed in front of our house, so I've loaned him my car for 6-8 weeks until his gets fixed. Anyway, he and I both concluded that my stereo sounds like hell with an AUX cord. It's grainy with no depth or punch to it, worse than FM radio. We've tried different phones, different aux cords, etc without improvement. Are they all like that, or does mine have a problem? Is combox A2DP streaming better?
12-14-2017, 12:52 PM | #2 | |
403
Rep 1,425
Then get HK under seats bass. It's day and night. |
12-14-2017, 01:51 PM | #3 | ||
712
Rep 971
Drives: 2018 M2
12-14-2017, 02:47 PM | #4 | |
264
Rep 459
I initially played with the gain, I think I need to fiddle with it some more. I set the car gain pretty high figuring it would amplify cleaner than the phone would. I need to revisit that.... |
12-14-2017, 03:43 PM | #5 |
29
Rep 64
I bought one of those Y cables to hook my Ipod up, and that was a waste. The audio sounded like garbage like you stated and seemed like it only played out of one side. Im now using a flash drive with mp3's and it sounds so much better.
12-14-2017, 04:35 PM | #7 |
Clean is the new cool, keep it that way.
808
Rep 1,685
Your device has more to do with it than anything else. But if you switched phones I dunno. Mine sounds great with my HTC U11 but my daughters iphone 7 sounds pretty crappy.
12-15-2017, 07:33 AM | #8 |
3975
Rep 7,215
I think it depends on the device you use - my old phone's audio jack sounded terrible, but over bluetooth it sounded great (using a bluetooth adapter to plug into the aux jack in the car). My new phone's bluetooth connection sounds like total crap, it's completely unlistenable - even on other audio devices that sounded fine before like my wireless headphones.
12-15-2017, 08:51 AM | #9 | |
2194
Rep 5,023
What bluetooth adapter are you using? My iPhone 7 also sounds like garbage via the Aux cord. Enough that it makes me wonder if upgrading speakers, etc. are even worth the effort. |
12-15-2017, 09:26 AM | #11 | |
3975
Rep 7,215
I don't think it's the stereo because it sounded completely different with the BT adapter, and obviously it's using the same Aux input. |
12-15-2017, 09:44 AM | #12 |
111
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
The aux sounds fine. Most probably cause to your issue is that your music source is distorted. Try disabling (flattening) any EQ or "enhancements" settings on your music source. Another source of potential issue is any ground loops if your music source is powered by the vehicle.
12-15-2017, 10:44 AM | #13 |
1707
Rep 14,829
I have an iPod (remember them?) connected to my aux, and when I do use it, it sounds just fine.
The cable (charges and does aux out) that I have today, is the 2nd one since 2007. The first one started going bad and yes it did cause the sound to also be bad, dropping out, etc. In this day and age the aux cable is a weak link, but music sounds just as good as anything else when it working. My .02. |
12-15-2017, 04:49 PM | #14 |
2194
Rep 5,023
I guess what I’m complaining about is when you compare a CD to the AUX there is a large difference in quality. Same tracks, same music.
I can turn up the CD very loud and despite the fact the sound system is merely ok it sounds decent. Try the same with the Aux and it sounds grainy and muddy at mid-high volumes. |
12-15-2017, 05:38 PM | #15 | |
403
Rep 1,425
What software do you use to play music through your phone? |
12-15-2017, 05:50 PM | #16 | |
403
Rep 1,425
What device you use do affect the sound quality. Usually, with an Android device, you can play with the Eq, High, mid, low. But I usually leave it alone. The Bluetooth version of the phone do matters too. The music file do affect sound quality. If you download your music make sure it is 320kbps. In theory: Aux do have a better sound output than Bluetooth. Most idea aux: A decent quality aux cord should be alright Most idea Bluetooth setup: A Bluetooth receiver with Qualcomm aptx |
12-15-2017, 06:18 PM | #17 |
340
Rep 922
I listen to my music through my iPhone 7 plugged in via AUX. It sounds great, so I can't relate to the above posters saying their iPhone sounds crappy in the car stereo.
Some things to note are that I never have the volume at maximum on either the phone or the stereo, and I'm sure if I turned it up too high at any point in the system, the quality would suffer dramatically. Definitely don't rely on the car stereo amplifying the gain for you-- leave that AUX-VOL setting or whatever it's called on the default... Also, be sure to clean lint out of the AUX port on the phone (not kidding, it can cause tremendous static) and only use high quality cables. After double checking all of the above, I'd probably start trying different phones and even take a ride in a different E90 if possible. I'm no audiophile but the sound quality has never been remotely bad enough for me to consciously notice. In my mind, if you buy a BMW, the minimum sound quality you deserve starts at "good enough," and if it's not, then something is wrong with the equipment (phone, cable, car stereo, etc.)
2006 330i 6MT Jet Black / Black
12-15-2017, 07:34 PM | #18 | |
111
Rep 2,017
That's because your 06 330i's came standard with L7 system which is pretty good. Even the the standard radios that came in the 06 325i / 07-09 328i's were pretty decent too. The 2010 / 2011 standard radio were garbage. It was awful. |
max_330i340.00 |
12-15-2017, 09:28 PM | #20 |
Normal Person
148
Rep 862
Drives: 2011 E90 335i
I have a high end stereo in my car but the aux sounds fine. If you are playing mp3 files off your phone there is no way it will ever sound as good as a cd. Especially if you downloaded that mp3. Look into uncompressed audio formats or at least set your mp3 at 320 kbps. I have iphone 6s and use Apple Lossless file format instead of mp3 when possible, files are bigger but sound quality is better than mp3.
tlow982194.00 |
12-18-2017, 05:57 PM | #21 |
25
Rep 38
I use this same device, and I have the controller just between my armrest and iDrive knob so I get quick track controls at my finger tips. I was actually super impressed with the quality of sound I'm getting. Once a call comes in it switches to the car Bluetooth, then returns to the kinovio once the call has ended without any extra fiddling.
02-26-2018, 05:24 AM | #22 |
Rep 4
Yes, good point I had the same problem and fix it with new cables now can listen all mp3 from my device downloaded from that site: https://vid-tube.biz
