In need of a Rear Main seal diy
12-13-2017, 08:59 PM | #1 |
64
Rep 156
I have searched and searched for a rear main seal diy in the DIY section and google to no avail. Any help would be super appreciated.
12-13-2017, 10:26 PM | #3 |
119
Rep 228
Im currently in the process of replacing the rear main on my 335xi. So far I've removed exhaust, heat shields, front and rear driveshafts, and trans fluid. From there it's just a matter of removing wires and connectors from transmission, followed by the torque converter/bell-housing bolts, and a few other things lol. I'm doing this on some cribbing blocks I made out of 2x4 for extra height. I may have to drop the subframe for clearance, not sure yet. I'll post back.
There are two different rear main seal sizes, and a lot of confusion on which one to use. I spoke with the shop Forman at my local BMW, his recommendation is to replace with the same size removed. You also need a special primer and sealant from the dealer. |
12-20-2017, 07:17 PM | #5 | |
119
Rep 228
Few things to note: -You'll need a 50mm wrench to remove rear driveshaft - All bell housing bolts are accessible from underneath the car. You will need about 3ft of extensions. - Bolts with blue paint should be replaced, but I did not. - The seal install tool is probably worth the money. I did not use it, but you really have to beat on it to get it to seat. (Risk of damaging seal) - No specified install depth (Because you're suppose to use tool), I installed flush with the block as recommended by others on the forum. - Exhaust downpipe bolts may be very rusty (climate depending) I had to cut off 3 and drill them out. - MAKE SURE torque converter is fully seated when reinstalling. Mine was actually stuck to flex pate upon removal. - I had to drop the subframe a couple inches to get the transmission to clear the tunnel. |
12-20-2017, 10:26 PM | #6 | |
64
Rep 156
12-21-2017, 05:48 PM | #7 | ||
119
Rep 228
12-22-2017, 09:31 AM | #8 |
Dealer Speed
64
Rep 140
12-22-2017, 12:15 PM | #9 |
323
Rep 1,025
As far as DIYs go, if you can find a DIY for clutch and flywheel replacement, that will get you 90% there I would imagine.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
04-13-2021, 12:42 PM | #11 |
Rep 15
