Kazoo/horn sound under WOT
12-11-2017, 09:20 PM | #1 |
65
Rep 342
Drives: 2007 335i E92
I'll try posting this again because I can't figure this out after a few months. I figure it has to be boost related because it doesnt make the noise under 10 psi. I tore the car apart to re install my VRSF reloctaed inlets to try and figure it out but no luck. Here is a link to the video. Dont mind the CEL and surging, my bov vacuum line popped off. Just listen to that sound...
Any ideas? I tightened every clamp that had to do with boost and still cant figure it out.
2011 X5 35d Daily - DUDMD Stage 2 and Deleted
2007 E92 335i - | Wedge Custom Tune | VRSF DP's| VRSF Race Intercooler | PE Mod Exhaust | Stage 3 LPFP | MMP Port Injection | VTT Stage 2+ Turbos | DKM Twin Disc | E85 | |
12-11-2017, 09:42 PM | #2 |
264
Rep 459
Is your BOV fluttering or acting up? Sometimes you need different springs based on boost level. People have also had issues with BOVs not liking the tiny port on the intake manifold. Some people upgrade to a larger port. I tapped a fitting into my manifold because the stock nipple was snapped off.
http://www.e90post.com/forums/showthread.php?t=1161102 |
12-11-2017, 09:46 PM | #3 | |
65
Rep 342
12-12-2017, 08:05 AM | #4 |
111
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
another thing to check is to your power steering pump. There was an issue with the clearance between the pulley and the subframe on early models when engine was under load.
12-12-2017, 08:11 AM | #5 |
65
Rep 342
I don't think it's that. When I lower the boost to stock psi but still go WOT it doesn't make the noise. That is what leads me to believe that it is boost related.
09-19-2019, 06:37 AM | #7 |
65
Rep 342
Yeah, old thread but it turned out to be the silicone coupler from my outlet to my intercooler. I would just make sure that all the couplers are really tight. No issues now.
