BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > My New 318i edition SE 2008... With Issues
      12-11-2017, 11:09 AM   #1
mistertml
Drives: BMW 318i SE Edition
Hi All
I have just purchased a 2008 318i edition SE as a second car.
I picked it up fairly cheap as it has the following issues:
- Only the Drivers Door Unlock/Locks with the remote. The rest have to be manually opened and close.
- The windscreen washer doest work. The pump makes a sound but nothing comes out. There is fluid in the reservoir so I'm assuming it is a blockage.
- Auto Stop function doesn't appear to work.
- 2 Tyres need replacing. I also seem to have a spare alloy wheel in the boot.
- Front Passenger side bumper/spoiler needs popping out.
- Humming noise coming from the rear
- Only One Key
Its not all doom and gloom.
As its a Edition SE I have the following (and working order):
M Sport Steering Wheel
M Sport Gear Knob
Leather Seats
Puddle Lights
Cruise Control
Parking Sensors
Electric Windows and Mirrors
Aux
The condition of both the interior and exterior (apart from the bumper) are ok.
As mentioned above this is a 2nd car (my second E90 after a horror with a 320si)
Hopefully the issues I have listed above aren't too costly. Most of them I can live with but will need to address the washer and tyre issues first.
Any advice an thoufgts will be great;y appreciated.
Thanks in advance
      12-12-2017, 03:00 AM   #2
jamherber
12
Drives: E90 330i N53 & Lotus Elise
Washer pump blockage very common - build up of sludge in the bottom of the tanks leads to strainer on pump being blocked.
Relatively easy DIY fix though - on the front drivers side you'll need to remove all the wheel arch liner parts and then the tank slides out. Should take around an hour if you haven't done it before.
Plenty of guides on this site if you search.
      12-12-2017, 05:29 PM   #3
mistertml
Hi
Thanks for the reply.
I thought as much. Hopefully once we go past the -4 temp here I'll give it a go.
Many Thanks
      12-13-2017, 09:40 AM   #4
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Auto start/stop on a 2008?
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      12-13-2017, 11:51 AM   #5
mistertml
Hi
Yes it has the auto start/stop button but not working as far as I know.
I’ve not used it since I picked it up so not sure if this is the case.
Thanks
      12-13-2017, 12:06 PM   #6
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
Originally Posted by mistertml View Post
Hi
Thanks
You're lucky then! You don't have to get it programmed off.
      12-13-2017, 03:54 PM   #7
mistertml
I guess it's a blessing in disguise
      12-14-2017, 01:51 AM   #8
creepy coupe
1867
2009 335i  [0.00]
Strange. I have a 2008 E92 without stop/start
Current car.M240i.
      12-14-2017, 07:55 AM   #9
mistertml
Update - Door Issue
Hi All
I have checked the fuses 56 and 57 and neither have blown.
The front Door is the only door that locks/unlocks and the rest are manual.
Is the next option to take it to an auto electrician?
Thanks
      12-14-2017, 08:14 AM   #10
creepy coupe
1867
2009 335i  [0.00]
Hi All
Thanks
Just a though. Have you set the door locks in the idrive just to open the drivers door? I set mine to comfort. Which does them all. Unless i leave the key in the slot and get out through the drivers door. then it only unlocks the drivers door.
Current car.M240i.
      12-14-2017, 09:10 AM   #11
mistertml
Hi
My car doesn't have the idrive function. I don't think I can set the door to lock/unlock any other way.
The internal lock button doesnt unlock the other doors either.
Thanks
      12-14-2017, 09:14 AM   #12
creepy coupe
1867
2009 335i  [0.00]
Hi
Thanks
Sorry i mislead you. My car doesn't have idrive. i meant to say by pressing the BC button on the left stalk while the key is in the slot. You can scroll through to door lock settings and change them to drivers only or all doors
Video here. About 1.27 sec into the video.
Current car.M240i.
      12-15-2017, 03:27 AM   #13
mistertml
Hi
I I have checked these settings and turned the drivers door only to all doors unlocked. But this has still not helped.
Also the internal lock switch only unlocks the drivers door and the boot.
Thanks
      12-15-2017, 03:37 AM   #14
creepy coupe
1867
2009 335i  [0.00]
Hi
Also the internal lock switch only unlocks the drivers door.
Thanks
Ah pity. Sounds like you need the help of a auto electrical tech.
As a last resort. have you tried disconnecting the battery to reset the systems?
Good luck.
Current car.M240i.
      12-15-2017, 04:18 AM   #15
AndyVR
12
Drives: E91 320i 2010 MSport
Auto Start Stop function won't work if your battery is getting old. Even with a fresh battery, this time of year it will need long runs to have enough charge for the system to allow Start/Stop.
2010 E91 320i MSport
VW Corrado VR6
      12-15-2017, 04:28 AM   #16
mistertml
Good luck.
Hi
Is it best to just remove the negative and plug back in after 10 seconds?
Thanks
      12-15-2017, 04:29 AM   #17
creepy coupe
1867
2009 335i  [0.00]
Hi
Thanks
Yep that's all I did when My M3 decided to not close the windows and lock the car.
Current car.M240i.
      12-15-2017, 06:02 AM   #18
mistertml
Hi
Thanks for that.
I'll give that a go later and will let you know how I get on.
In other news I keep getting a chime for blown rear bulb and Ive checked them all and they all seem intact and not blown.
Thanks
      12-16-2017, 06:11 AM   #19
mistertml
Silly question
But I appear to have a black cover over the negative terminal.
Which I can’t seem to take off.
Thanks
      12-17-2017, 06:56 AM   #20
mistertml
So I managed to disconnect the battery for around a minute and then plugged it back in. But my door fault remains.
The question is how do I find out which actuator(s) needs replacing?
My fuse numbers are 61, 72, 73 And 79.
73 has a 20amp fuse in it.
Thanks
      01-11-2018, 08:02 AM   #21
mistertml
Update
I thought I'd update on the latest on the car...
I have replaced all 4 tyres.
The humming noise from the rear was a rear driver side bearing which has also been fixed.
I have added a Sony aftermarket HU I took out of my old X3 but currently awaiting delivery of a pioneer which has bluetooth so that will sort all my music connections out. USB and Bluetooth are missing from my setup.
I also installed a set of Vibe Slick 4 on back. but not changed the door speakers so unsure if the sound has improved or not yet.
I will be replacing the front door actuators this weekend seen as I found a set sold by BMW for £65ish as opposed to a lot more for the single door actuator.
      01-13-2018, 06:21 PM   #22
mistertml
Door Actuators Replaced
I finally got round to replacing both the front door actuators.
Now my driver door still locks/unlocks with thekey and from inside.
The two rear doors can only be locked and unlocked manually by pulling the leaver and locking pressing the from inside the car.
The lock button on the centre of the dashboard doesnt have any affect on the rear doors.
On a side note
I replaced my old Sony CD Player with a Mechless Pioneer HU with bluetooth. I ran the 12v switched live to Fuse #2 and connected the red-red and yellow-yellow on the harness. The memory is fine and the cd player only turns on when the key is in the car which saves me having to remember to turn the CD player off like with the Sony HU.
I also fitted some speakers in the doors but not really had chance for a listen as was pushed for time.
Thanks
