Smoking from exhaust..can't find a straight answer
12-09-2017, 11:16 AM | #1 |
30
Rep 79
Just a few previous points;
- My car's a 2009 335i e92 - My turbos were replaced around 68,000 (Currently at 75500), so I doubt it's my turbo seals. - I checked my spark plugs both before and after driving, no fuel smell no excess fuel either. My car starts smoking slightly transparent smoke from the tailpipe when idling and after driving and getting to a stop. It doesn't smell like eggs, so it's not my secondary cats. It's not very thick white smoke, so I doubt it's my coolant..It does not smell sweet either, it smells like gas. Here's the link to the video: Any help is appreciated, thanks. |
12-09-2017, 12:32 PM | #2 | |
30
Rep 79
It continues to do it even after driving for a while. Nearly every time I stop it begins to do that slight smoking. |
12-09-2017, 02:52 PM | #3 | |
Paul C
88
Rep 162
TheBingoBalls3836.00 |
12-09-2017, 04:55 PM | #4 |
264
Rep 459
The combustion of gasoline produces water vapor, which BMW exhaust systems seem to collect. It didn't get there from a car wash. Long trips help to burn it off. My 540i resonators had over a gallon in them.
Both of my 335s made lots of vapor, especially in cooler weather. That's the likely explanation. Obviously smoke is another option whether it's from gasoline (leaking injector), or oil from turbo seals(common) or valve stem seals(rare). Head gasket issues are super rare on the n54, so it's probably not coolant. I would definitely check out those injectors if they are below index 11, leakers are common on index 9 and lower. Remember that injector seals MUST be replaced any time the injector is reinstalled. Where did your turbos come from? |
12-09-2017, 10:06 PM | #5 | |
30
Rep 79
My new turbos were replaced under the BMW recall. I live in South Florida so the smoking was in 68 degree weather, something I guess wasn't taken into account considering every other place in the States is FREEZING. I just really wanna make sure my car is running fine before adding more power. My front mount comes next week and I'm waiting to order my stage 2 fuel pump and inlets outlets |
12-11-2017, 04:15 PM | #7 | |
30
Rep 79
The only reason I'm concerned because this is completely random and hasn't happened before. |
12-11-2017, 05:01 PM | #8 |
264
Rep 459
That definitely indicates a problem. Pop off your engine cover and make sure the high pressure fuel lines are tight. People sometimes have fuel leaks after doing the valve cover gasket. The high pressure fuel lines are tricky to accurately torque, you need either a crowfoot wrench and a torque wrench, or the special BMW socket tool.
12-11-2017, 05:07 PM | #9 | |
30
Rep 79
