Help! What is this plug??
12-09-2017, 10:59 AM | #1 |
251
Rep 395
Drives: 2006 M5, 2012 X5d, 2008 E91
I posted a while ago about oil leaking onto my exhaust manifold and burning off causing fumes to enter the cabin. I finally found the leak, but I have no clue what the plug(?) is. You can see the plug in between the manifold flanges in the second photo.
You can see the oil beading up on the exhaust flange in the first photo attached. It appears to be weeping out of the plug, collecting on the flange and dripping on the manifold below. Does anyone know what this plug is for? I figure I'll pull off the exhaust manifold, remove the plug, coat the threads in high-temp RTV and hope for the best? |
12-09-2017, 01:04 PM | #3 |
251
Rep 395
Perfect, thanks! I couldn't find it anywhere.
I'll update when I get it all back together! |
01-09-2018, 08:26 PM | #4 |
251
Rep 395
So I finally received the part numbers listed and the screw plug is not the same. The screw plug in the cylinder head is a female hex style and the part I received, p/n 11-11-7-535-694, is a male torx style.
Anyone know if the two are interchangeable? I'd rather not pull the headers off to find out... |
01-09-2018, 08:45 PM | #5 |
161
Rep 357
Hi have you checked Real OEM for your car?
http://www.realoem.com/bmw/enUS/show...diagId=11_3734 I think its the screw plug for the cylinder head: 11127521440 |
