RB PCV valve question
12-08-2017, 06:58 PM | #1 |
65
Rep 342
Drives: 2007 335i E92
I installed the PCV valve but when I close the cap I can hear it rattle in there when I tap it. Is that normal? Do I have to push it harder in?
2011 X5 35d Daily - DUDMD Stage 2 and Deleted
2007 E92 335i - | Wedge Custom Tune | VRSF DP's| VRSF Race Intercooler | PE Mod Exhaust | Stage 3 LPFP | MMP Port Injection | VTT Stage 2+ Turbos | DKM Twin Disc | E85 | |
12-09-2017, 08:41 AM | #2 |
151
Rep 460
Not sure I have the answer to that. When you shake the PCV valve yes it does rattle and is in fact supposed to. I would check to make sure the cap is screwed in all the way and not cross threaded. If it is I'd call it a day.
If your still unsure contact Rob and BMS and he will confirm. |
12-09-2017, 10:11 AM | #3 |
1907
Rep 6,968
12-09-2017, 10:23 AM | #4 |
65
Rep 342
Shortly after I posted that I realized what it was. I forgot that when you shake the RB PCV valve it rattles itself. When I unscrewed the cap the pcv valve was tight in there so it shouldn't be an issue.
