My 335i creaks like a pirate ship while turning!
12-08-2017, 02:21 PM | #1 |
'07 E93 335i Sport
20
Rep 120
Hey all, was wondering if you can help em diagnose an issue I've been having. Only occurs during low speed turning, mostly when reversing or turning into parking spaces. The noise can't really be heard outside of the car but can be heard pretty clearly by everyone inside the car. I'd love to know what's causing it and how I can fix it. I'm guessing it's somewhere along the steering rack.
"Space Grey Space Ship"
JB4, BMS DCI, ALPINA Flash, Cobb CP, VRSF 3' Catless DPs, Magnaflow X-Pipe, PE-mod, 437M, PS4s, M3 Control Arms, M3 Paddles, Follow Me on Instagram! Last edited by MrSilverwing; 12-08-2017 at 02:28 PM.. |
12-08-2017, 03:19 PM | #2 |
2124
Rep 2,758
The general consensus is either something is loose up front(control arm/steering rack/sub frame bolts), worn strut mounts/hats, or worn sway bar end links.
12-08-2017, 07:51 PM | #3 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
The power steering on these cars do like to 'groan'. It's normal. Make sure your PS fluid has been serviced
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
12-08-2017, 07:56 PM | #4 |
Life is better with burnouts
99
Rep 611
Drives: BMW
I believe that is the sound of the rubber boot of the steering shaft through the firewall. Just needs to be greased.
12-08-2017, 09:36 PM | #5 |
Crazy Frog
543
Rep 1,212
Change the exhaust fluid...
12-08-2017, 09:51 PM | #6 | |
1909
Rep 6,968
Check the torque settings on all the nuts on every control arm and strut in the front end. If you still have the creek at low speeds, start with the sway bar bushings & links. If still, replace the control arms & tie rods If still, replace shocks & struts plus surrounding hardware (strut bearings, bump stops, etc....) |
12-09-2017, 07:30 AM | #10 |
5532
Rep 5,443
Drives: Beige G31 40ix m sport
Second that. Mine made a similar noise I changed the top mounts & that cured it as well as making the steering feel smoother.
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
12-09-2017, 10:46 PM | #11 |
'07 E93 335i Sport
20
Rep 120
I had the control arms and bushings upgraded 2 years ago, so that shouldn't be the issue. I've attempted to lubricate the plastic ring underneath the rubber boot, but I probably didn't use the right product. What did you use?
JB4, BMS DCI, ALPINA Flash, Cobb CP, VRSF 3' Catless DPs, Magnaflow X-Pipe, PE-mod, 437M, PS4s, M3 Control Arms, M3 Paddles, Follow Me on Instagram! |
12-10-2017, 12:14 AM | #12 |
Touring cars rock
351
Rep 907
Make sure everything suspension related is torqued at ride height. If you have had any work done on anything suspension related it could be that any number of fasteners were torqued unsprung. Not only will this get noisy, it will destroy bushings in no time.
Sportwagon Daily: I've done some stuff.
