12-01-2017, 10:19 PM | #1 |
21
Rep 38
Engine Hesitation with JB+ on B58 M240i
Hey guys,
I recently installed a BMS JB+ tune on my ///M240i (6/MT), have been running it at the default 4psi setting for about 2 days now. 90% of the time the increase in power is quite thrilling, but from time to time I experience the engine cutting off or hesitation under WOT. This generally occurs in higher gears, 3 and 4. I'm quite sure Socal 91 Octane has something to do with it...I may bring the boost level down to see if the issue is resolved. Any other suggestions or similar experiences out there? Thanks!
2017 BMW ///M240i|EB II|6MT|BMS INTAKE| AWE CATBACK EXHAUST | BM3 STAGE 1
SOLD: 2014 BMW 228i M-Sport |EB II|6MT SOLD: 2011 BMW 135i M-SPORT |SPACE GREY|6MT SOLD: 1999 BMW M3 |ESTORIL BLUE - DOVE GREY IG: @petro.sexual |
12-02-2017, 02:05 PM | #2 |
102
Rep 303
Suscribed.
petrosexxual20.50 |
12-02-2017, 02:42 PM | #3 | |
44
Rep 55
AlexM240i101.50 petrosexxual20.50 |
12-03-2017, 07:53 AM | #4 | |
Tarnished One
76
Rep 362
09 LMB M3
Retired: 05 MB 330i, 08 CS 135i, 17 EB M240i, 13 CB 135is, 16 ABM M4 |
12-04-2017, 06:10 PM | #5 | |
102
Rep 303
petrosexxual20.50 |
12-05-2017, 08:41 AM | #7 |
1165
Rep 1,931
I ran jb+ on n54 as well, no issues and run it on the n55 ontop of a flash tune without any problems.
I also installed one on a completely stock n55 m235 and hasn't had a problem either. Could be octane, could be shitty gas, bad plugs, etc..
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
Rockstar148776.00 petrosexxual20.50 |
12-06-2017, 01:19 PM | #8 |
Joint Chiefs of Staff
24079
Rep 190,597
OP you need to datalog, You probably need to change your spark plugs ... Bringing the boost down will help but eventually they will fail even on stock car.
petrosexxual20.50 |
01-15-2018, 10:02 AM | #10 |
102
Rep 303
Having the same issue with my JB+ even using octane booster in my 8Auto M240i. I had to turn the dial to half boost to prevent the laggy shifting. Not happy with it....
petrosexxual20.50 |
01-19-2018, 10:14 PM | #11 | |
21
Rep 38
AlexM240i101.50 |
01-19-2018, 10:17 PM | #12 | |
21
Rep 38
Rockstar148776.00 AlexM240i101.50 |
01-19-2018, 10:19 PM | #13 |
21
Rep 38
Yes the mystery of what the issue is still bothers me. I did not have much issues with my N55 135i, and many friends with N54 E90/2 or E82 had a pretty smooth experience.
01-19-2018, 10:24 PM | #14 |
21
Rep 38
So having some issues with 8AT M240i as well? I was convinced it had to with clutch slippage, but it does seem like Octane is the primary issue. Octane booster has helped, it's a shame we have to turn the boost down a few notches. When I tried 4.5+ psi and things ran smoothly for a few brief moments, the power was incredible! But all in all, whether +2psi or +3 psi, the performance gain is still great considering it's less than $200, and very easy to remove and install. I recently installed a AWE exhaust as well, I feel like this initially caused a bit more hesitation, but after 200 miles or so, all was relatively smooth 95% of the time.
AlexM240i101.50 |
01-19-2018, 10:25 PM | #15 |
21
Rep 38
Good to know! What are your thoughts on continuous use of Octane Booster? I'm tempted on every fill up, but have stopped using it the last 3 weeks.
01-19-2018, 10:29 PM | #16 |
21
Rep 38
Not a bad idea Mike! Probably will provide the most definitive answer or atleast eliminate some variables. I just figured at 3.5k miles on the odometer, my spark plugs should be pretty good? I recall N20 users often suggesting the use of S55 Spark Plugs for tuned engines. BTW thanks for the awesome shopping experience, I just installed the AWE exhaust before New Years. It has completely transformed the car. I'm shifting better with the enhanced sound, the pops and bangs never get old. Catted downpipes and suspension are next on the list
01-19-2018, 10:40 PM | #17 |
21
Rep 38
Some fun with the AWE Exhaust. I should get better videos soon, this was just pure hoonigan behavior. This is what happens when your visiting the family for the holidays and the your younger brother's friends want you to do a burnout.
SOLD: 2014 BMW 228i M-Sport |EB II|6MT SOLD: 2011 BMW 135i M-SPORT |SPACE GREY|6MT SOLD: 1999 BMW M3 |ESTORIL BLUE - DOVE GREY IG: @petro.sexual Last edited by petrosexxual; 01-19-2018 at 10:56 PM.. |
01-21-2018, 05:47 AM | #18 | |
444
Rep 1,262
Sunoco gas doesn’t meet BMW’s standard for injector cleaning. Basically, the only gas you should put in the car comes from a gas station that sells top tier gas. See www.toptiergas.com. Off soapbox! I replaced the injector o-rings on my now departed 2001 E46. The only gas I put in the tank was top tier gas. The bizness end of each injector was pristine. I credit the cleaning additive package in the gas for the injectors’ condition. |
01-22-2018, 03:42 AM | #19 | |
Tarnished One
76
Rep 362
Sunoco is on the list of top tier gas! you should’ve looked at the website Off soap box! Cool story bro Sunoco ultra 93 is on the list of top tier gas!
09 LMB M3
02-14-2018, 11:33 PM | #20 |
19
Rep 39
I get the same hesitation from my Dinan tune as well, I'm pretty sure that it's California hippy gas causing the issue. I've put in 3 gallons of 100 and the rest 91 to make 93, didn't notice the issue as much. I do see inconsistent power deliver as you do with the JB4 tune, maybe heat soak, I don't know but it sure is annoying.
02-15-2018, 07:51 AM | #21 | |
64
Rep 107
