11-29-2017, 08:34 AM | #1 |
285
Rep 1,289
m perf brakes
I have done some research on the m performance brakes and it seems the general consensus is that they aren't worth the money at least for regular street driving. However, I do track my car several times per year and so I'm wondering if they might be worth the money for someone like me? Any thoughts?
11-29-2017, 09:06 AM | #2 |
447
Rep 1,161
all you get is a bigger diameter front disc. basically that's it. 370mm Vs 340mm and then obviously the bigger caliper to accept the disc. but that is it.
the disc supplied is t even fully drilled so you get some squeal noise from trapped air. not worth it. just use the money to invest in discs, pads, lines and fluid
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
11-29-2017, 09:56 AM | #3 |
Gangnam Member
229
Rep 136
I installed them on my 228i. With the recent fire sale prices on the kits I found them to be a good value. The upgrade from the base 228i is significant. I autocross infrequently and get to the track about once every two years. I'm quite happy with my choice to install the M Performance Brakes.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC |
11-29-2017, 10:19 AM | #4 |
424
Rep 980
They are very good brakes. But mine squeal like billy-o when first used cold.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
11-29-2017, 10:31 AM | #5 | |
447
Rep 1,161
bit on a 235/240 it ain't worth it.
2014 M5
11-29-2017, 12:37 PM | #6 | |
1403
Rep 5,262
11-29-2017, 12:39 PM | #7 | ||
447
Rep 1,161
2014 M5
11-29-2017, 12:51 PM | #8 |
3848
Rep 2,873
An extra 30mm of diameter is pretty significant - remember that braking force acts via leverage, so a bigger disc gives an advantage (like when you put the pipe on the end of that lug wrench). Also a lot more metal to help dissipate the heat. Probably no real advantage on the street (perhaps even disadvantages from noise, dust, etc.), but it can be a big deal on track.
11-29-2017, 01:01 PM | #9 |
4517
Rep 8,942
Right so the most cost effective upgrade to maintain use of 17" wheels is when rotors are due for replacement get the slotted drilled ones in stock size, and keep the stock calipers.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-29-2017, 01:06 PM | #10 | |
447
Rep 1,161
To run 17" wheels you need to keep 340mm front disc. So spend on upgrading discs and pads. Also lines and fluid.
2014 M5
11-29-2017, 01:59 PM | #11 |
1657
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
i have OEM 18' wheels on my 228i...i'm already considering the m-perf brake kit when i need to do brakes & rotors during my regular maintenance schedule. any reason to look at other non-OEM brake kits to upgrade? other recommendations that may provide a better value?
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
11-29-2017, 03:34 PM | #12 |
Old Member. Old in general, actually.
388
Rep 889
Unless you can't get into the ABS, or you track the car, the M Perf brakes seem to me to offer little. And they are likely less effective when cold.
11-29-2017, 03:40 PM | #13 |
1165
Rep 1,931
no, they are not worth the upgrade...
That being said, if you are running the OEM sized mperf rotors and need to replace, it makes more sense to buy the kit because it comes with pads, rotors, and new calipers for little difference in price. A set of front and rear mperf rotors are over $1k. They now have some aftermarket rotors that a dimpled and slotted that cost less, i haven't tried them yet.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-29-2017, 03:43 PM | #14 | ||
285
Rep 1,289
related question for those of you with the m performance brakes. how is the brake dust because the dust on the m sport ones are horrible? in fact I can clean my wheels and by the next day and after only driving a short distance I am already seeing buildup of brake dust. |
11-29-2017, 04:27 PM | #15 |
1165
Rep 1,931
brakes are dusty...
powder coat ur wheels black.
www.nybmwcca.org
11-29-2017, 05:35 PM | #17 | |
8937
Rep 2,010
So no, the M brakes aren’t worth it. Definitely take them back and get a refund.
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
11-29-2017, 07:33 PM | #18 |
1165
Rep 1,931
www.nybmwcca.org
11-29-2017, 07:55 PM | #20 | |
1330
Rep 2,214
I've done 345 --> 370mm rotor upgrades on my prior VAG cars and it really seemed to help at the track, definitely unnoticeable during regular driving. It really helps with the 200+km/h hard braking sections where they experience the most heat. Now these BMW's do have better brake cooling features and more ducting than the VAG cars I've owned, but you can't get away from the simple fact that the larger surface area and increased rotor mass will aid in cooling. Maybe on a minimal level, but still an aid. To me, for the small upfront cost, it can be a worthwhile investment, for the right end user. A full on MP BBK, not really worth it, unless heavily discounted. Just my $.02
Maynard3848.00 |
11-29-2017, 09:57 PM | #21 |
285
Rep 1,289
11-29-2017, 10:00 PM | #22 | ||
285
Rep 1,289
Dylan861330.00 |
