11-28-2017, 11:05 PM | #1 |
Rep 65
idling issue after fix bigger IC n charge pipe on 328i
Hi all
Does anyone face idling issue after fixing bigger IC and charge pipe? usually when coming to a stop, the idling will drop around 550rpm which make the engine about to die off... is there anyway to bump up the idling? Thanks |
11-28-2017, 11:36 PM | #2 |
3101
Rep 4,350
you should not need to fuss with the idle after changing your fmic and/or charge pipe(s). i would think there is a leak or one of the sensors not put back.
11-29-2017, 01:18 AM | #3 | |
Rep 65
Yeah it should not affect the idling. Everything was re checked twice. No leak spotted as the boost can hit 17psi (still on stock map) |
11-29-2017, 03:40 PM | #4 |
664
Rep 1,074
Had the same issue, it's your fuel pump or you have a dirty intake clogging it. Get k&N drop in filter
Instagram: M2_Medusa
11-29-2017, 11:33 PM | #5 |
Rep 65
11-30-2017, 12:09 AM | #6 |
664
Rep 1,074
The only idling issues I had was the car bouncing and the issue with that was the valvetronic motor, the second issue I had was the car shutting off at idle because it wasn't pumping enough fuel because I was running to much ethanol. Doubt it's your intercooler. Try and get codes ran. You don't need a cel for codes to populate
