Condensation and water droplets inside headlights on a new car, is this normal!? |
11-25-2017, 05:25 PM | #1 |
40
Rep 102
So I picked the car up Monday last Tuesday (brand new), car had been obviously been washed prior to me collecting, headlights we’re fine when I collected it and for the first few days they were fine, weather was quite mild for the time of year, experienced a bit of heavy rain and they were still fine, I then drove it yesterday to my parents (about a 2 hour drive) Arrived and noticed the outside temperature had dropped a fair bit to what it had been like. Thought nothing of it but when I went back to it an hour later I noticed a considerable build up of water droplets at the top of both headlights.
I emailed the dealer right away and he called me back saying He had seen it on a lot of cars but to monitor it and it may have to come back under warranty. I used the car again today, headlights on for a fair amount of time and if anything they have got worse, now a foggy condensation on the bottom (the first 4 pictures are when I arrived yesterday and the bottom 2 are from just now) Apparently the heat of the lamps should dry out any condensation but doesn’t seem to be doing it in my case? Also do the lights generate enough heat to clear up any moisture? I also notice almost like a glass burn on the inside of the glass when the headlights are on. Like 3 circles with a line through them, hard to explain and not sure if it’s a reflection from the lights, makes them look old and slightly worn. Is this normal? Do they need replacing? Will it simply happen again if they are replaced? If one headlight was like it I would think a possible faulty light but they are both like it. |
11-25-2017, 06:03 PM | #2 |
5554
Rep 5,372
The housing are not air tight. They're designed to vent. Big temp swings could cause this especially when the dew point is low. Watch it for the next day to two. They should dry out.
11-25-2017, 06:08 PM | #3 |
1330
Rep 2,214
IIRC it even states what XutvJet mentioned. in the owner's manual. Same with our GTI, also in the manual. This is normal, in this day/age.
11-25-2017, 06:08 PM | #4 |
40
Rep 102
That what I thought and I know there are vent holes but I made a point to check lots of cars today and everyone else’s seemed fine, every bmw I passed I stopped to check and none were like mine and they would have been under the same temperature changes as mine. I’ll keep monitoring it.
11-25-2017, 11:52 PM | #5 | |
Rep 10
Whilst at first sight, it doesn't seem correct, it appears as if it is 'normal'! Both my wife's car and mine do this, she has an Audi and I have a 2 series coupe Lci. I noticed that the headlights on both cars will fog internally when I wash them. Hope this helps? Happy motoring. Andy |
11-26-2017, 02:10 AM | #6 |
195
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
I had my taillights do this, they were replaced under warranty. As said above, they are not air tight so this can happen and it still does on mine too, but now only the condensation happens without droplets. The criteria from BMW to replace them under warranty is if they have water droplets next to the condensation. The size of them effects if they will change them or not. From what I can see from your pictures is that they should be changed under warranty as there are big droplets in there. Just take it to your dealer/service and show them the pictures. I attached the part of BMW Driver’s Guide where it mentions it, hope this helps...
11-26-2017, 02:53 AM | #7 | |
40
Rep 102
11-26-2017, 05:05 AM | #8 | |
195
Rep 366
Drives: 218i Coupe
11-26-2017, 01:29 PM | #9 | |
40
Rep 102
I drove home, headlights on all the way, an hour and a hal journey but the droplets we’re still there. I have a feeling they will dry out eventually but I still don’t think it’s right. |
11-26-2017, 11:31 PM | #10 | |
195
Rep 366
Drives: 218i Coupe
11-27-2017, 05:57 AM | #11 | |
40
Rep 102
Anyway today I checked today and they seem to have dried out with just a slight residue. I’m getting it ceramic coated next week which will involve a wash and being kept inside so I’ll see what it’s like after I pick it up and bring it out into the cold again Atleast I’ve mentioned it to the dealer and have 3 years to keep an eye on them. |
01-06-2018, 10:46 AM | #12 |
40
Rep 102
So a quick update, the droplets have come and gone depending on temperature but today on the passenger headlight there is an unslightly mark on the inside of the lense as shown. Also slightly foggy.
Headlights just look old and dirty, very unsightly. I’m going to email the pictures to the dealer. No idea how this can happen. |
