BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Brightness knob not working?
      11-25-2017, 03:17 PM   #1
wheresmy5
58
Drives: 2019 540i xDrive M Sport
Losing my mind here. I? was able to adjust the brightness using the dimmer knob to the left of the steering wheel but now this dial does nothing to adjust the screen and cluster brightness. I'm sure there is a setting somewhere I? need to change. Any ideas?
      11-25-2017, 06:25 PM   #2
wheresmy5
58
Still don't know what caused this, but after I restarted the car the knob worked again.
      11-26-2017, 02:38 PM   #3
wheresmy5
58
I now understand what happened. I had the windows tinted in the am, and when the car was returned, it was still daytime. In daytime, it appears that the brightness knob does't actually do anything. When I restarted the car, it was dark outside; in the night, the brightness knob works as expected.
My question is, how do you brighten the screen in the daytime?
      06-07-2018, 04:07 AM   #4
The Donald
Thailand
Drives: 520d G30
i've been told that if you coded your instrument cluster to "Alpina Display" the brightness knob will no longer work.
perhaps Almaretto can help me confirm if this is true.
      06-07-2018, 04:30 AM   #5
en1gma
en1gma's Avatar
198
Drives: G03 X3
I have coded to the Alpina dials and can confirm the brightness knob does work - at least for me.
I'll have to check the daytime vs nighttime query, though...
      06-07-2018, 07:15 AM   #6
en1gma
en1gma's Avatar
198
Drives: G03 X3
Just checked and cannot alter brightness of the Alpina console in the daytime via the knob, but it does change automatically depending on the ambient light (e.g, bright sunshine, dark underpass, etc).
You can change via the knob at nighttime.
      06-07-2018, 08:58 AM   #7
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
I though I saw a beta option in coding to separate the dash brightness from the other lights to allow selective dimming of the "bright" Alpina display without overly dimming the ambient lights, etc.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      06-08-2018, 12:37 PM   #8
530iDriver
530iDriver's Avatar
1708
Drives: 2017 BMW 530i
I think the dash illumination is governed by a photo sensor and it may override the slider switch on the dash...
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      03-27-2019, 10:07 PM   #9
saporitj
281
Drives: 2019 540ix M Sport
Probably still losing my mind but at least not about this anymore. My car is doing the same thing. The brightness knob works in the garage but when I pull it out into the sunlight nothing. Thought I was crazy or something changed after coding other stuff but looks like BMW designed it that way, crazy. I owe someone an apology for thinking it was something they did. I'm sorry. No names. 🙏
JS
      03-28-2019, 02:13 AM   #10
BMW_Sweden
45
Drives: 540iX G30
I thought I was losing my mind..
During the whole winter I changed the brightness up and down due to the sun/dark periods... It worked regardless of the light outside... The past days I felt it was too low and wanted to bring the brightness upp but nothing happens... not down either...
Then during the evening yesterday it worked again.... wtf
      03-29-2019, 02:55 AM   #11
Almaretto
Almaretto's Avatar
2373
Drives: Test Vehicles
Alpina has nothing to do with it. There is sensor in cluster and coding must be adjusted for IC, HU, and controls.
That can be software related.
      03-29-2019, 06:45 PM   #12
hlothery
Seeking mental floss
482
Drives: 2022 Mercedes EQS 450+
And, in my opinion, the sensor is calibrated by someone high on cocaine. The brightness changes inexplicably. I love the bright setting, but sometimes it just goes dim, even in bright sunlight. I have to take off my sunglasses to see the display. This is the only thing I dislike about my car.
      05-04-2019, 08:40 PM   #13
wheresmy5
58
Funny, a year and a half after creating this thread for my previous 540, I have the same issue with my new 540 just picked up today. Surprised that they hadn't corrected this (it's absolutely a poorly implemented feature) in the 2018s or 2019s. Luckily, an easy DIY fix... time to code that same parameter...
      05-11-2019, 09:07 AM   #14
wheresmy5
58
For anyone else annoyed by this, I can confirm that coding the dim_variant parameter to "old" fully resolves the issue in the G30. The idrive brightness is now fully controllable via the menu, irrespective of fluctuations to ambient light.
      05-11-2019, 09:24 AM   #15
AP
AP's Avatar
2705
Drives: G30 M550
I always find it interesting as to how many things are configurable and the fact that at some point there must have been some meetings to go through all of these settings and sign them off.
Some are market specific or due to regulations some such as this?
Wonder why these option are even here in the first place if they appear to not be offered as an option anywhere.
Would love to know the train of thought behind all of this from the bmw engineers
      05-11-2019, 09:38 AM   #16
wheresmy5
58
It might be a programming call. I'm sure they don't code every version of idrive from scratch. Instead, they add to the existing code. What legacy bits remain can be accessible via OBD coding. In other words, they're not adding anything, it's just what accumulates after many years of revisions/patches/upgrades.
      12-04-2019, 09:26 AM   #17
ejlover06
ejlover06's Avatar
Turkey
105
Drives: 2017 G30 520 1.6lt
But the main issue is with the instrument cluster and this doesn't solve that problem. At least for me. iDrive screen has a good brightness regardless of the outside lighting but I'm having issues to read the instrument cluster around 5-6pm during sunset since cluster goes into night mode but there is a bright light outside.
      12-04-2019, 10:22 AM   #18
AP
AP's Avatar
2705
Drives: G30 M550
I know what you mean , the red is perhaps a little dark at that short period of the day as the sunsets or rises.
I recall my f10 being the same but the e39 as it was an analogue display was fine as the white was as bright as ambient light was and when it got too dark the red backlighting took over.
I think it's fine but agree taking things to the nth degree that it might be a bit better
Search this Thread:
Advanced Search
5post
