Oil leak between engine and transmission? Possibly RMS?
11-24-2017, 09:17 PM | #1 |
Crazy Frog
543
Rep 1,212
Hi there,
Hope you all had a wonderful Thanksgiving. I was doing and oil change and tranny fluid change yesterday and I noticed some oil between where the back of the engine block meets the transmission. Is this a rear main seal leak? How serious is it? Can I get away with driving it for another year or so and just selling it or should I get it fixed asap? See pics: View post on imgur.com View post on imgur.com
11-25-2017, 12:10 PM | #2 |
264
Rep 459
My rear main seal blew out of the engine and gushed oil really bad. Mine was so bad that the car couldn't be driven, it would lose a quart in well under 100 miles. Check other possibilities first like oil-filter housing gasket, valve cover gasket, oil pan gasket, etc. I always recommend fixing problems as they appear so that you don't accumulate a massive list of maintenance requirements. You can continue to drive it as long as you keep the oil level up. I've tried a variety of stop-leak and gasket sealers, they don't work. I spent $700 to have my rear-main seal done.
11-25-2017, 05:20 PM | #3 | |
Crazy Frog
543
Rep 1,212
My VCG is dry as a mofo and so is my oil pan. I just did an oil change and inspected the seams of the pan like crazy. Not a drop of oil. There is only oil where the transmission meets the back of engine block.
11-26-2017, 01:49 AM | #4 | |
264
Rep 459
Rear main seal leaks aren't exactly common on the n54, but they aren't rare either. |
11-26-2017, 12:55 PM | #5 |
2194
Rep 5,023
N52 RMS leaks are extremely uncommon. It is, however, very common for a leak to develop on the backside of the oil pan gasket, which mimics a RMS leak.
Just a heads up before you go too deep down the RMS black hole. How bad is the leak? A slow seeping oil pan can stay in the same state for years... and doesn't necissarily need to be replaced. |
BimmerNugget542.50 |
11-26-2017, 08:55 PM | #6 | |
Crazy Frog
543
Rep 1,212
06-04-2023, 12:04 AM | #7 | |
Rep 10
06-04-2023, 12:07 AM | #8 | |
Crazy Frog
543
Rep 1,212
The leak was so slow it didn’t really matter. Just drive it til you see oil stains on your driveway.
